Code 36 burn off relay, where is it??
Old Dec 26, 2003 | 06:49 PM
scarabexc's Avatar
scarabexc
Default Code 36 burn off relay, where is it??
I thought it was behind the bread box, also I am using a 86 book on this 87, I assume the code 36 is the same, Please help, Thanks :banghead:
Old Dec 26, 2003 | 06:51 PM
C4396roadster's Avatar
C4396roadster
Default Re: Code 36 burn off relay, where is it?? (scarabexc)
relays are behind battery on driver side
Old Dec 26, 2003 | 07:11 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Behind battery, (2) both the same, at auto zone $9.00 each... I just replaced both
Old Dec 26, 2003 | 07:12 PM
belmor's Avatar
belmor
Default Re: Code 36 burn off relay, where is it?? (vinnies87)
I did the same, they can be a bear to get unplugged with the battery in, but all in all not too hard-once its done unhook the battery for a min or 2 to clear the code
Ben
Old Dec 26, 2003 | 07:17 PM
scarabexc's Avatar
scarabexc
Thanks, Off to autozone
Old Dec 26, 2003 | 08:39 PM
scarabexc's Avatar
scarabexc
Thanks guys, that fixed it!!!! :hurray:
Old Dec 29, 2003 | 01:13 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I had to replace mine twice. The first one was defective. I thought there was another problem thinking that the new relay was good. It took me 3 months to figure out that the relay that I bought was bad. Good luck
Old Dec 29, 2003 | 03:06 PM
vinnies87's Avatar
vinnies87
:cool:
To Code 36 burn off relay, where is it??
