Looked thru archives and didn't get what I wanted.
Put the new master cylinder in and I can't bleed the slave. There is a flat "nipple". Can someone point me in the right direction, do I need a special tool like a "Phoenix tool", yada? Thanks.
This slave has been off and someone stripped the bleed screw. I backed it out and I'll have to tap it or something to use it. Or get a replacement slave tomorrow. Thanks to all who read and sorry to bother.
Good idea. If it's the same maybe I can just order the screw. I can tap it and then lock tight the screw and put a hex nut or bleeder valve in it. :cheers:
