knock senser detection
Dec 27, 2003 | 08:09 PM
how so I tell if I'm getting knock retard if I have a noisy engine and can't hear detonation on an 85 corvette? :crazy:
Dec 28, 2003 | 07:57 PM
Re: knock senser detection (lead foot 85 vet)
one way is the car will lose power do to timing retard or you can buy the ezlink and plug it in the computor when you drive and that will show you about $199.00 for the ez link
Dec 28, 2003 | 08:48 PM
Re: knock senser detection (6spd)
Thanks I'm super charged and am not getting the top end hp I should...I'll look into buying one. :yesnod:
Dec 29, 2003 | 10:50 AM
Forum member JoBy came up with this a while back....
[Modified by GRX, 8:12 AM 12/29/2003]
Dec 29, 2003 | 03:03 PM
Re: knock senser detection (GRX)
What does that do?
Dec 29, 2003 | 07:52 PM
The LED (triangular symbol) will light up whenever the ESC module 'tells' the computer there is engine knock. The "1K" indicates a resistor with a 1000 ohm resistance...probably 1/4 watt type. Actual resistor value will depend on the LED rating.
[Modified by GRX, 4:54 PM 12/29/2003]
Dec 29, 2003 | 08:51 PM
cool I thought the triangular symbol was a diode...couldn't figure out how it was going to work :crazy: thanks GRX I think I can build that . :cheers:
Dec 29, 2003 | 09:59 PM
Well, it is a diode; but more importantly, it is a Light-Emitting-Diode (LED). Good luck! :cheers:
