Torque Specs for 94 Corvette
Old Dec 28, 2003 | 12:22 PM
kalyko's Avatar
kalyko
Default Torque Specs for 94 Corvette
Probably a dumb question for anyone with a shop manual, but when changing the thermostat, what should the bolts be torqued at when re-installing? Also.....how important is it to torque the wheels to 100 ft. lbs. Could that create a problem if not to that exact spec?
Don
Old Dec 28, 2003 | 04:06 PM
VenkmanP's Avatar
VenkmanP
Default Re: Torque Specs for 94 Corvette (kalyko)
"Thermostat housing bolt" is 18 lb ft
The wheel torque doesn't have to be exact. 90-110 would be fine. You do probably want to try and get them all about the same on one wheel.
Old Dec 28, 2003 | 05:07 PM
sraft's Avatar
sraft
Default Re: Torque Specs for 94 Corvette (steve9899)
:iagree: I've read that improper torquing of lug nuts can lead to premature brake rotor warpage.
Old Dec 28, 2003 | 06:29 PM
bogus's Avatar
bogus
Default Re: Torque Specs for 94 Corvette (sraft)
no... the surface of the wheel is too flush with the rotor to cause that (with minor deflections) you would have to run only 2 lugs for that to happen...
Old Dec 28, 2003 | 06:48 PM
kalyko's Avatar
kalyko
Thank you very much for the info......I really appreciate it as I do a lot of WINTER maint. here up north.
To Torque Specs for 94 Corvette
