[QUOTE] do you need to reprogram a chip for 21#injectors?? probably for max HP gain...but considerign your other changes wouldn't hurt
what is the stock rev limiter set to?? before I started to mess with my program I could've sworn it was 6000. There is no fuel entry beyond 5600 RPM.
is my fuel pressure set to low for 21# i set it at 42psi with line on?? You should set it with either the line off or at idle. People are very adamant either way...just make you do it the same way every time
and why does my motor die out at 3800-4000 rpm everything is new? Get a scanner toolie thingy and see for yourself
