Code 32 (EGR) diagnostics
Old Dec 29, 2003 | 02:04 AM
cash's90's Avatar
cash's90
Default Code 32 (EGR) diagnostics
My '90 L98's Check Engine light came on for a period of time last night and then went out. I checked the code memory today an EGR fault (code 32) was displayed. The diagnostic check looks simple enough but when I attempted to pull the vacuum hose "manifold" off of the EGR solenoid it did not pull off as easily as I expected. Should it pull straight off of the solenoid or is there a retainer that I cannot see? I always worry when these things seem harder to remove than I expect. :confused:
Old Dec 29, 2003 | 03:53 AM
86PACER's Avatar
86PACER
Default Re: Code 32 (EGR) diagnostics (cash's90)
If what you are referring to is that rubber piece with 2 vaccum hoses on the EGR solenoid, next to the thermostat housing, it pulls off with some neddle nose pliers. It is only pressed in horizontally. No clips or anything.
I just went through this a few days ago. I also got the Code 32 flashed.
I replaced the EGR switch that is threaded to the EGR pipe and the "Check Engine" light does not come on anymore.
Here is a website you might find useful, if you have not alredy hear about. http://www.c4vettes.com/ecm.htm
It has descriptions of trouble codes and their most common cause.
It has helped me out a lot.
:thumbs: :D
[Modified by 86PACER, 1:01 AM 12/29/2003]
Old Dec 29, 2003 | 11:25 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Code 32 (86PACER)
:thumbs: :thumbs:
Old Dec 29, 2003 | 12:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed you are wise to use care in handling those hard plastic vacuum lines.
I carefully pry that vacuum connector away from the EGR solenoid fittings with a flat blade screw driver till the line connector is loose.
Also there is a diagnostic method on my site (link in sig. below) that uses engine vacuum for fault isolation.
Old Dec 30, 2003 | 03:19 AM
cash's90's Avatar
cash's90
I believe the EGR switch was deleted for the '90 and newer models. I'll go ahead and pull the vacuum manifold and continue the diagnostics.
To Code 32 (EGR) diagnostics
