roller rocker question
Thanks guys...... :cheers: :cool:
what sizes is the stock size.... also,, what size stud?
And do I need self aligning??????
[Modified by 1990CORVETTE, 7:55 PM 12/29/2003]
But in general I suggest Comp. Cams parts:
-ProMagnum 1.6:1 RRs for 3/8" studs
-hardened pushrods
-hardened guide plates
-valve springs
-hardened locks (keepers)
-stock GM upper & lower valve seals
Your stock rockers are self-aligning and stud size is 3/8".
You will need to remove the studs to get rid of the stock non hardened guide plates so you might as well install hardened guide plates & pushrods and use the cheaper non self-aligning ProMagnum RRs.
You should also toss the stock tin oil shedders from atop the springs to lighten the valve train a little (these were not used on the LT1 engine).
If you later plan to do heads, cam, exhaust, intake and such you might want to use a little different valve train. In fact I would wait till after you chose a cam to do the valve train upgrades.
upgrades.
-ProMagnum 1.6:1 RRs for 3/8" studs (be sure you know if you are buying self aligning or not)
-hardened pushrods (usually .100" longer with RR's)
-valve springs (I wouldn't even bother until you change cam/heads)
-stock GM upper & lower valve seals (teflon will require machining so the neoprene/stock would be a good alternative)
You will need to remove the studs to get rid of the stock non hardened guide plates so you might as well install hardened guide plates & pushrods and use the cheaper non self-aligning ProMagnum RRs. (i fyou go self aligning you can keep these or just replace them with a washer)
Since you are buying RRs, I'd opt for 7/16's rockers, same price.
And, yes, be sure to check with the company that makes the RRs, some call for longer pushrods.
Be sure to check for interference too; retainer to seal; .060 between coils a full valve lift (although you can fudge that # a bit and run a bit tighter). I've run as tight as .035 with no problem; as long as you don't the valves; .060 is safe though.
Setting the lifter preload with the new rockers can be tricky if you're not familiar with doing it. Lots of guys have problems when it comes to that area.
Guys who work on engines a lot all have their favorite way of doing it, I'm no exception. I prepared a MSWord file that details how I do it; if you'd like I can send it to you.
Good luck; hope this helps.
Jake
