Backfiring Engine!
Old Dec 30, 2003 | 08:06 AM
87BLKVETTE's Avatar
87BLKVETTE
Default Backfiring Engine!
I have a 87 Vette with a 175K L-98. After not running the car most of the late summer and fall, I charged the battery to run some fuel stabilizer through the system to prepare for winter storage. The initial startup sounded hideous, then after warming up started to sound like a Vette engine again. Then came some awful backfiring and smoke. I had posted earlier in the year about minor backfiring and power loss, and was advised that I might have some excessive carbon buildup. I was told to carefully spray some water (mist) through the throttle body to dislodge carbon from the tops of the pistons. I have a MAF system and am a little skeptical about how to do this. The shortblock was dealer replaced at 140K, but I'm sure that the top end is stock, except for the injectors that look awful large. I could use some advice and a good mechanic in the Connecticut area. I have done a lot of things to my Vette on my own, but tearing into the engine is not within my comfort zone. Thanks in advance.
Tony Lopes :cool:
Old Dec 30, 2003 | 08:42 AM
bogus's Avatar
bogus
Default Re: Backfiring Engine! (87BLKVETTE)
it sounds like you have some screwed injectors... there may be 1 or more that are stuck open... gunked up from sitting.
I donno if the stablizer did that, or if just being idle did it...
Old Dec 30, 2003 | 09:26 AM
rick lambert's Avatar
rick lambert
Default Re: Backfiring Engine! (bogus)
Maybe condensation built up in distributor :rolleyes:
Old Dec 30, 2003 | 10:33 AM
C10 JDR's Avatar
C10 JDR
Default Re: Backfiring Engine! (rick lambert)
Have you checked the ignition timing?
Old Dec 30, 2003 | 03:58 PM
BIG JIM 54's Avatar
BIG JIM 54
Yeah....
When I installed my 52mm throttle-body (I have a lot of porting done as well), it back-fired like crazy from a dead stop. Then I read a tip here that setting the TPS at 7.2V-7.4V instead of 5.4V like the manual said, would richen the off-idle mixture. Did that and it was cured.
Back-firing is an indication of a lean mixture, among other things. Check for stored codes and proper initial timing.
Something to try.
BIG JIM
Old Dec 30, 2003 | 05:46 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Did you cross up ignition wires?
Just a simple question.
tony
:flag
To Backfiring Engine!
