One more Converter Question
RACE ON!!!
PS. I think that idle problem may be helped by some tuning. Has that been attempted? If that converter is coming from where I think it might be, he does chips, too. Does a '95 use a chip?
[Modified by CFI-EFI, 11:05 AM 12/31/2003]
It will not idle at the original 550-600rpm that your auto LT1 prescribes as stock. It'll have to be bumped up to at least 850rpm.
PS, get http://www.pcmforless.com/ to tune your car, you will be extremely happy. They are not expensive and will keep tuning till your happy.
[Modified by steve40th, 5:37 PM 12/31/2003]
Also, for your idle you can raise the idle timing a few degrees, but you have to reprogram the chip to lower your max timing everywhere else. What really did the trick for me was to modify the stall saver RPM settings in the program as well.
RACE ON!!!
The Hot cam, while it has a catchy name, is infact a relatively mild camshaft and should idle well at 800/850 rpm. 218 @ .050 shouldn't be doing what yours is, so something isn't right.
My first thought is PROM programming too.
If their is a really noticable difference of idle quality with the trans in neutral Vs when it's in gear, then the converter is pulling the engine down. But even so a 218 shouldn't be acting that way unless the idle speed is much too low and/or you have a vacuum leak.
Your engine should be putting out over 300 HP at the rear wheels considering the parts you're using.
If you want to see the power difference a Vigilante 2800 makes with a Hot cammed 350, check of this site: http://www.eecis.udel.edu/~davis/z28/winter01/dyno/
Just my thoughts.
Jake
[Modified by JAKE, 2:00 AM 1/1/2004]
... After destroying my Edge converter, my local tranny guys voiced a low opinion of its quality.
I have to admit, my local boys built me a converter that has a noticeable difference from the "Edge".. My current one delivers much more power and is still efficient on top.
Andre at Edge Racing Converters is a very nice guy.. but the cast stators from 4 cylinder foreign autos and crummy tolerances won't hold up to anything over stock horsepower.
I'm sorry to have to ditch http://www.edgeracingconverters.com .. but the $450 I spent with them cost me about $1200 in rebuild costs.
As consolation to Andre.. my boys were able to salvage the front half of the converter... it was the only part within tolerance.
The Vigilante caused the loss of power at high RPMs, probably due to the slipage.
It gave a sizable power increase down low, but gave up some up top.
Jake
It's got a 9 inch impeller section for little to no slippage around town and it's mated to a billet housing for an 11 inch lockup clutch.
It's also delivering 1.9 sec 60 foot times on street tires. :smash:
I'd say, looking at your dyno numbers, you are in desperate need of tuning. I'm not sure what kind of hp/tq numbers cars with the the hotcam are putting down, but I have to assume you should be making more power than that.
Yes I felt the same when I was shown what it pulled on the dyno. I was not real sure what it should get but did kind of hope for more. I at least wanted to hit 300 HP.
So Steve40th you have a Vigilante 2800 and HIGHLY recommend the 3.75. I may look into that. Well thanks for all the info just have to pick where Im going to get it from. Maybe after I get this done and the gear it will go in for e retune.
