Lt-1 Max R.P.M.
Old Dec 31, 2003 | 10:56 PM
Cherry6speed's Avatar
Cherry6speed
Default Lt-1 Max R.P.M.
I have heard the stock lt-1 rods will come apart around 5800 R.P.M. any truth to this or can I wrap it up higher? :crazy:
Old Dec 31, 2003 | 11:00 PM
Bruce's Avatar
Bruce
Default Re: Lt-1 Max R.P.M. (RUBYREDVETTECARD)
Wrong....
When I my 93LT1 350ci with head and cam setup. I rev the motor to 6200-6500 no problem what so ever.
Bruce
93LT1 Supercharged
Old Dec 31, 2003 | 11:36 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Not for me...my LT1 is stock...never been touched and I hit between 5900 and 6000 rpm 3 times every run at the drag strip...btw, I had 218 runs last year... :D
Old Jan 1, 2004 | 01:15 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I shift at over 6000 rpms everytime I hit the track.
Listen to the LT1 sing here:
http://temp.corvetteforum.net/c4/mrmojo2//mojo.wmv
Old Jan 1, 2004 | 09:57 AM
Atok's Avatar
Atok
I don't think they will come apart. My stock '95 PCM has the fuel cutoff (rev limiter) in 1st gear set to 5886 RPM, 2-6th gear is 5805 RPM. I doubt GM wouldn't program the rev limiter higher than what the engine can reliably handle.
Old Jan 1, 2004 | 10:53 AM
STL94LT1's Avatar
STL94LT1
My stock bottom-end LT1 regularly sees 6200 rpms.
To Lt-1 Max R.P.M.
