Why won't my '86 dash lights do anything?
Old Jan 2, 2004 | 08:47 PM
Cooter's Avatar
Cooter
Default Why won't my '86 dash lights do anything?
Well, not exactly my '86 anymore, but my former car's dash will not respond to higher/lower settings on the headlight switch or change intensity in bright light. The new owner has replaced the headlight switch and has messed with it for a few days, but can't get it to work right. Anything else he needs to look for?
Thanks!
Old Jan 2, 2004 | 08:51 PM
vader86's Avatar
vader86
Default Re: Why won't my '86 dash lights do anything? (Cooter)
Either his light sensor is bad, or all 4 bulbs need replacing. The bulb # is 882.
Old Jan 2, 2004 | 08:55 PM
hngacurv's Avatar
hngacurv
If you are saying that the headlights are on, but don't get brighter with the flip of the switch the light green wire from the dimmer switch could be stuck in open loop.
Old Jan 2, 2004 | 08:56 PM
hngacurv's Avatar
hngacurv
Default Re: Why won't my '86 dash lights do anything? (hngacurv)
Are you talking about headlights or the dash?
Old Jan 2, 2004 | 09:10 PM
Cooter's Avatar
Cooter
I appreciate the responses so far, but I was not specific enough- sorry about that.
The dash lights work, but they are always at the same brightness level. At night, open daylight, with the dimmer turned high or low, the cluster stays the same. The problem is that they are at a lower light level and in daylight, it is very hard to see the cluster, but at night, that same level is too much. I don't know what to do about this one and could really use some help.
Old Jan 2, 2004 | 09:33 PM
hngacurv's Avatar
hngacurv
Then what Vader said.
Old Jan 3, 2004 | 11:46 AM
jfb's Avatar
jfb
The circuit on the cluster circuit boards varies the dash lighting by changing the pulse width it supplies to the lamps from info from both the headlight dimmer control and the photocell. If the headlight dimmer has been replaced, then you still have the wiring from the dimmer to the cluster and the possibility that the photocell is defective or the IC in the cluster is dead. It sounds like the cluster needs to be looked at by a service center.
To Why won't my '86 dash lights do anything?
