dyno #'s - how does this sound...
Old Jan 4, 2004 | 10:30 AM
Z06_BluByU's Avatar
Z06_BluByU
Default dyno #'s - how does this sound...
329 hp & 489 ft/lbs @ 3500rpm.. (flywheel) These are from my LT1 Stroker, stock TB, Stock heads, bigger cam, 10.8:1 compression and no cats... they have not been correlated on the local eddy current dyno yet.. these are desktop Dyno numbers from a datamaster run.. I dont think they are dead on acculate but I'm thinking they probably give a good idea.. I'm headed to the local dyno shop sat.
Does this sound about right? only adding about 30 fwhp :sleep: and 149 ft/lbs (flywheel) :eek: or have you guys found this desktop dyno stuff to be total crap...
Old Jan 4, 2004 | 11:42 AM
scorp508's Avatar
scorp508
Default Re: dyno #'s - how does this sound... (BluByU)
Sounds really weak to be honest. I don't trust desktop dyno for a single minute when it comes to HP guesses.
Old Jan 4, 2004 | 12:20 PM
STL94LT1's Avatar
STL94LT1
Datamasters dyno was about 50hp shy on my car.
Old Jan 4, 2004 | 06:59 PM
R23HTC's Avatar
R23HTC
Default Re: dyno #'s - how does this sound... (STL94LT1)
I've got a similar setup. (check my sig) The HP is about right but I don't think you'll get that high on TQ. I'm getting around 329rwhp and 362rwtq. That was on a flakey opti though. I'm hoping to do a little better next time out. :D
Old Jan 5, 2004 | 09:34 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: dyno #'s - how does this sound... (R94 LT 1)
BTW: that is supposed to be flywheel hp/tq.. I think yours is rear wheel hp/tq.. but either way.. It seems like an awfully big split between the tq and hp #'s.. :yesnod:
Old Jan 5, 2004 | 09:44 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I used Desktop Dyno on my last 406 and when using actualy cam card info and head flow numbers, it was pretty darned close.
If you don't have this information, it really is just a guess.
Old Jan 5, 2004 | 10:20 AM
scorp508's Avatar
scorp508
Default Re: dyno #'s - how does this sound... (LT-4 CE)
According to DD with this info I should have about 500HP. :rofl:
Old Jan 5, 2004 | 11:26 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: dyno #'s - how does this sound... (scorp508)
this isnt with the program desktop dyno.. its with the desktop dyno option on datamaster.. which basically turns your car and the road into a huge accelerometer :yesnod:
Old Jan 5, 2004 | 03:41 PM
R23HTC's Avatar
R23HTC
Yes, my numbers are rear wheel.
Old Jan 5, 2004 | 05:13 PM
VMAX451's Avatar
VMAX451
At what rpm is the hp peak? If your torque is 489 ft/lbs @3500 rpm, you are already making 326 hp at only 3500 rpm. Surely your hp peak will be at a higher rpm than 3500.
Old Jan 6, 2004 | 09:03 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: dyno #'s - how does this sound... (Vince Ivanc)
peak hp was also @ 3500 rpm
To dyno #'s - how does this sound...
