3.73s
Old Jan 4, 2004 | 02:05 PM
shabbadoobie's Avatar
shabbadoobie
Default 3.73s
I have a 84 vette crossfire how much would 3.73 or 4.10 help and dose anyone know how much they cost? THANKS :auto:
Old Jan 4, 2004 | 02:36 PM
bogus's Avatar
bogus
Default Re: 3.73s (shabbadoobie)
The rear end in the 84 is a D36, across the board. the biggest you can fit is a 3.73 without upgrading to the D44.
I think gears are about $200~$250 or so... PLUS!!!! Installation!!!! It is NOT a job for the shade tree mechanic. It requires special tools...
I would look for a D44 and new c-beam... the D44 will up you to 3.45 rear gears... that will be a huge jump!!!
The overall price will be about the same, with much greater upgradeablity.
I would also look at performance mods to the xfire... there are things you can do that will really help performance... there are newer intakes and options available. I am sure that other xfire owners will eventually chime in...
Old Jan 4, 2004 | 02:38 PM
scorp508's Avatar
scorp508
.....how much would 3.73 or 4.10 help
0
.... and dose anyone know how much they cost?
You would be looking at around $275 for a GOOD set of gears and then another couple hundred if you pulled your own differential out and brought it to someont to install.
Old Jan 4, 2004 | 03:46 PM
STL94LT1's Avatar
STL94LT1
Unless your 84 no longer has the crossfire engine in it, 3.73 or 4.10 gears will hurt your performance.
To 3.73s
