plenum question
Old Jan 4, 2004 | 07:55 PM
91z07's Avatar
91z07
Default plenum question
Found a nice ported/polished plenum for sale, but it's off a MAF car. Will it work on my '91, and if so, what would it take to work? :thumbs:
Old Jan 4, 2004 | 08:03 PM
1MoorTym's Avatar
1MoorTym
Default Re: plenum question (91z07)
The only difference I know of is the threaded fitting used for the MAP sensor. The MAF plenum will not have one. Check the passenger side for a third threaded fitting above the taps for the FPR and ?? (jeez I forget what the other vac fitting is for), but there should be a total of three for use with the MAP system.
You could probably have one put in at any machine shop.
Old Jan 4, 2004 | 08:08 PM
ZD1's Avatar
ZD1
The only difference I would know about is if there is a 9th cold start injector.
To plenum question
