Pushrod length (89 L98)
Old Jan 5, 2004 | 06:42 PM
C10 JDR's Avatar
C10 JDR
Default Pushrod length (89 L98)
I have fitted 1.6 rr, and the rocker seems to favour the outside of the valve stem.
What is the standard length of the pushrod, and should I go shorter or longer?
Old Jan 5, 2004 | 07:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Pushrod length (britvette)
Our stock pushrods are:
7.195" long
5/16" od
When I installed 1.6:1 ProMagnums I used stock length hardened pushords and they were pretty well centered across the valve stem tip. That's with tightening 1/2 turn + 1/8 turn past zero lash.
You could get a length checker pushrod from say Comp Cams, adjust it to center the rocker tip and compare it's length with that of the stock pushrod.
Old Jan 6, 2004 | 05:40 AM
C10 JDR's Avatar
C10 JDR
Default Re: Pushrod length (65Z01)
Thanks for that info, I needed it to buy the correct length adj. pushrod, to do as you suggest.
:cheers:
To Pushrod length (89 L98)
