As we are getting closer to finishing the motor, I'm having more doubts about the Stealth-Ram to put on this beast. There are so many unknowns with it that I'm starting to lean more towards a modified LT1 intake ported to match the heads.
Anyone out there know if there is enough material to port the LT1 intake to a 1206 gasket? We are running Brodix M2 T1x 227's on the beast, and this is the gasket it uses.
Would I be better off using an LT4 intake? Is there any difference between the two?
