UNDER HOOD LIGHTS
Old Jan 6, 2004 | 10:54 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
Default UNDER HOOD LIGHTS
When I open my hood the 2 lights do not light up, the bulbs are good. What should I look for next???? :confused: :sad:
Old Jan 6, 2004 | 11:02 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: UNDER HOOD LIGHTS (midlifecrisis91)
Is your fuse OK?
[Modified by Tony.96LT4, 10:05 PM 1/6/2004]
Old Jan 6, 2004 | 11:06 PM
midlifecrisis91
Default Re: UNDER HOOD LIGHTS (Tony.96LT4)
I pulled all my fuses and they checked out good....Still lost.... :(
Old Jan 6, 2004 | 11:08 PM
ffvetteman's Avatar
ffvetteman
First if you follow the wires down the hood you will see connectors at the bottom. Make sure they are hooked up. If they are, get a volt meter. Pull the bulbs out and check if you have power at the terminals.
If no power, stab the wires just below the housing and see if theres power there. If there is, then the mercury switches are bad and need to be replaced.
Keep us informed.
:steering:
Old Jan 7, 2004 | 12:03 AM
subman's Avatar
subman
Default Re: UNDER HOOD LIGHTS (ffvetteman)
Keep us informed.
:steering:
:iagree:
Old Jan 7, 2004 | 12:52 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree:
Old Jan 7, 2004 | 01:35 AM
JasonL's Avatar
JasonL
Default Re: UNDER HOOD LIGHTS (vinnies87)
The fuse for these lights is NOT in the fuse block... it has it's own holder near the driver's headlight. Just follow the wires.
Many people pull this fuse, so it's just something to check.
Old Jan 7, 2004 | 01:42 AM
Trog's Avatar
Trog
Default Re: UNDER HOOD LIGHTS (JasonL)
if your on a steep driveway the merc switch won't engage... :D
Old Jan 7, 2004 | 09:36 PM
midlifecrisis91
Default Re: UNDER HOOD LIGHTS (Trog)
I will troubleshoot further, thanks for the assistance.... :)
Old Jan 11, 2004 | 03:00 PM
mikey_vette's Avatar
mikey_vette
Does anybody know the correct part number for the mercury switches, or another place to get them from? I spend 1/2 hour with my local GM parts guy and we came to the conclusion that they were discontinued.
- Michael
Old Jan 11, 2004 | 07:31 PM
midlifecrisis91
Default Re: UNDER HOOD LIGHTS (mikey_vette)
Are the mercury switches mounted by the bulbs? and I can't find power anywhere when i put my meter to the plug. :crazy: I know this should be simple. :crazy: :crazy:
Old Jan 11, 2004 | 07:40 PM
xs650's Avatar
xs650
The mercury switches are little pill capsule shaped things that are up against one end of the bulb. At least they are on a 96. They are a fraction of the size of the bulbs
Did you check for power at the under hood light fuse in the lower front corner of the engine compartment?
It's unlikely that both mercury switches would be bad.
[Modified by xs650, 4:41 PM 1/11/2004]
Old Jan 11, 2004 | 08:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Try to never stab your wires with a test light when looking for power. I have seen corrosion run a long way up a wire from such little breaks in the insulation. If you MUST ever do this put a little dab of silicone over the hole. On these complex electronic vehicles big problems can be caused by such little details. They sell a switch kit to turn these light off and on as needed. This, of course could be easily rigged yourself, too. I don't like them on when I'm working on it in the shop. I just keep them unhooked at the connectors and made dummy weather-pack plugs to keep the dirt out.
To UNDER HOOD LIGHTS
