Bearings
Old Jan 7, 2004 | 03:12 PM
kohlbear's Avatar
kohlbear
Default Bearings
Has any one had a problem replacing only one front wheel bearing hub assembly? I replaced the rt. front three times with a BCA and it was worse than the original. They had movement. The car pulls to the left and has been aligned.I now have a chicago Rawhide from Pep Boys. But I am almost afraid to try another atermarket Hub assembly.
Old Jan 7, 2004 | 04:23 PM
vader86's Avatar
vader86
Default Re: Bearings (kohlbear)
This is why I never used the PepBoys bearing. I only used the AC Delco part.
Old Jan 7, 2004 | 05:27 PM
VetteNoob's Avatar
VetteNoob
I replaced a BCA bearing on the front rt a month ago and it already has play in it. I thought it may have been caused by the cupping in my tires causing some unusual vibration so I was going to wait until I replaced my tires before I replaced it again.
Old Jan 7, 2004 | 05:43 PM
Rick92's Avatar
Rick92
I know it costs more but I went with oem, 2yrs ago and no problems so far :cheers:
Old Jan 7, 2004 | 06:12 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Bearings (Rick92)
I replaced only one. The other's original with 108k on it.
... and I autocross with 335's up front.
Old Jan 7, 2004 | 06:22 PM
JasonL's Avatar
JasonL
Default Re: Bearings (vader86)
Pep Boys sells SDK, and I assume SDK has various suppliers. So there are various brands that will come in the same box... but some of the SDK boxes will have bearings identical to GM originals. Open the box and inspect them before buying.
Chicago Rawhide is supposed to be reputable from what I've heard...
Old Jan 7, 2004 | 06:49 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: Bearings (JasonL)
I've been told Chicago Rawhide makes the AC Delco bearings.
I just put them on the rear :cheers:
Old Jan 7, 2004 | 07:52 PM
69vetteracer's Avatar
69vetteracer
We go to Checker. They sell GMB, have installed dozens without a problem. Also have a lifetime warrenty. :chevy
Old Jan 7, 2004 | 10:13 PM
sraft's Avatar
sraft
Default Re: Bearings (69vetteracer)
PepBoys probably gets their bearing from several sources, so depending on where you live and when you buy, the brand could vary. The unit they sold me earlier this year was a Chicago Rawhide (CH) bearing. I did a little digging and discovered that CH is a subsidiary of SKF, which is a large and well respected bearing manufacturer. This made me feel a lot better about putting the CH bearing in my vette. You can bet that GM doesn't make bearings and I suspect that SKF is an OEM supplier to the auto industry, so I wouldn't be surprised if the Delco bearings are identical to (some of) the less expensive, third party brands.
To Bearings
