Rear Wheel Bearing Question?
Old Jan 7, 2004 | 09:47 PM
CG77VETTE's Avatar
CG77VETTE
Default Rear Wheel Bearing Question?
I'm sure there must be a good explaination, but can someone please tell me why the rear spring and tie rod end have to be disconnected in order to remove the rear bearing hub assembly? I'm only asking since all the shop manuals list this as a procedure but I fail to see the reason :confused: One shop manual even instructs you to remove the half shaft as well? Thanks for any help and I would appreciate any tips from someone who has done this repair on a base '86 Coupe.
Old Jan 7, 2004 | 09:54 PM
Wheelman's Avatar
Wheelman
Default Re: Rear Wheel Bearing Question? (CG77VETTE)
They don't, it just makes it easier to get the torx bolts on the back of the hub out. I did it without taking anything off except the wheel and the rotor/caliper. :cheers:
Old Jan 7, 2004 | 10:04 PM
sraft's Avatar
sraft
Default Re: Rear Wheel Bearing Question? (Wheelman)
:iagree: I did one of my rears last April without removing the spindle, u-joint or halfshaft.
CG77VETTE's Avatar
CG77VETTE
Thanks Wheelman, I was hoping that was the case. That means I will only need a twelve pack to get through the repair :D
Old Jan 7, 2004 | 10:05 PM
CG77VETTE's Avatar
CG77VETTE
Default Re: Rear Wheel Bearing Question? (sraft)
Hi Steve, thanks for the response. Winter is a good time to get intimate with our girls isn't it? Happy New Year!
Old Jan 8, 2004 | 01:28 PM
Z-PDX's Avatar
Z-PDX
I've done this twice.
Once just removing the wheel and disc/caliper. skill factor = 2, hassle factor = 8
Once by pulling the knuckle off. skill factor = 3, hassle factor = 3
I strongly recommend taking the time to pull the three additional bolts (camber strut, 2 control arms) it is so much easier than trying to pull the torx off blind.
-Z
Old Jan 8, 2004 | 01:50 PM
h rocks's Avatar
h rocks
Just be sure to use GOOD sharp Torx bit. You will have to rotate the hub to get to all the Torx bolts. Using a 1/2" drive with a swivel joint makes it a pretty easy job to get good torque on the bolts.
Old Jan 8, 2004 | 01:52 PM
Goody's Avatar
Goody
Default Re: Rear Wheel Bearing Question? (Z-PDX)
I would fathom a guess here that the manuals tell you to remove all that stuff because it is sometimes easier in time for a pro with good tools to do it that way.
It provides the technician with a good time to inspect any other wearable parts for replacement as well.
Also, and important, could be the accuracy of torquing the bolts back down. With extensions and/or universals one must add some extra torque value. Only a guess though.
Old Jan 8, 2004 | 03:00 PM
El Guapo's Avatar
El Guapo
St. Jude Donor '03
The only thing I removed to replace the rear hub was the caliper to give myself a little more room. If I ever have to do it again I might just remove everything though to make it that much easier.
Old Jan 8, 2004 | 03:40 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Default Re: Rear Wheel Bearing Question? (El Guapo)
The last thing I wanted to do was strip the Torx bolt on the rear bearing because of not having a clean shot at it. Believe me, removing the strut rods and control arm along with the half shaft makes it much easier. I pulled the entire hub out and cleaned it up using a wire wheel.
Old Jan 8, 2004 | 04:24 PM
brookman's Avatar
brookman
Default Re: Rear Wheel Bearing Question? (Dominic Sorresso)
With the half shaft rotated so the knuckle is not in the way and using a dental mirror you can get a straight shot at the torx bolts.
Old Jan 8, 2004 | 07:45 PM
RutsRup's Avatar
RutsRup
I did my rear wheel bearings with a torx bit and a really long extension. Didn't remove anything except the wheel. Of course, you have to elevate the rear end of the car to rotate the half-shaft to gain access to the bolts.
Old Jan 8, 2004 | 09:58 PM
LaVidaLoca's Avatar
LaVidaLoca
I know it is possible to replace the bearings without pulling the half shaft. But if the bearings are gone then the U-Joints need to be replaced also and this is a great time to do it. Pulling the shafts as noted above give you direct access to the Torx bolts. $.02
To Rear Wheel Bearing Question?
