internally balanced 383/406 stroker kit?
Old Jan 9, 2004 | 10:45 AM
devilfish's Avatar
devilfish
Default internally balanced 383/406 stroker kit?
Where should I look for them? With diffrent specs.
Thank you...
:flag
Old Jan 9, 2004 | 11:10 AM
Corvette0096's Avatar
Corvette0096
Default Re: internally balanced 383/406 stroker kit? (devilfish)
http://www.eaglerod.com/
Old Jan 9, 2004 | 11:15 AM
devilfish's Avatar
devilfish
Default Re: internally balanced 383/406 stroker kit? (Corvette0096)
I cant find any stroker "kits". "just" cranks..
Old Jan 9, 2004 | 11:20 AM
Corvette0096
http://www.oregoncamshaft.com/SmallBlockChevy.html
Here is a break down kit for compression and bore size.
http://www.racenet.net/eng/eag-assy.php
[Modified by Corvette0096, 8:24 AM 1/9/2004]
Old Jan 9, 2004 | 11:24 AM
85vet's Avatar
85vet
Cruise-In V Veteran
To get as much info as possible on stroker kits -
go to http://www.google.com
type in stroker kits and have fun looking at whats available.
check out http://www.speedomotive.com
http://www.strokerkits.com
http://www.flatlanderracing.com
Good luck, I researched the stroker setups and spoke to my local parts/machine shop and purchased locally for less than $50 difference than ordering off the internet. It helps to have info and be prepared.
Good Luck, you will enjoy the extra power and torque a 383 produces :yesnod:
[Modified by 85vet, 11:26 AM 1/9/2004]
Old Jan 9, 2004 | 11:31 AM
devilfish's Avatar
devilfish
Default Re: internally balanced 383/406 stroker kit? (85vet)
thanks!
To internally balanced 383/406 stroker kit?
