Re: E-brake won't racket up...what's the problem.. (NE14SIN)
There is a piece of plastic in the operating ratcheting system that fails. I don't remember exactly how to explain it. Mine was replaced under new car warranty, although I would not leave my LT4 at the dealership for mechanic test drives, I replaced it myself in the parking lot at the dealership. It is easy enough to replace. Removed the seat cushion and went to work. I do remember using a straight piece of wire inserted in a hole to hold something in check until a cable was connected. This happened in 1996. I had/have the service manual which helped.
Re: E-brake won't racket up...what's the problem.. (70ZZ3 96LT4)
man, i wish i had known about that idea before i just ripped mine out, that was the biggest pita ive had to do on the spot. it was all late, and i was like.. ah, lets see what this is like. bad idea. took lots of time and pain to get it back.
