'84 Driver side hood latch will not open...
Old Jan 9, 2004 | 06:50 PM
415ZR1's Avatar
415ZR1
Default '84 Driver side hood latch will not open...
Any hints on how best to open? The inside lever will only open the passenger side hood latch.
Thanks, John
Old Jan 9, 2004 | 06:59 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Re: '84 Driver side hood latch will not open... (415ZR1)
Look in some of the Corvette catalogs, they sell a long rod looking instrument that has a short L shape at the end that you put under the hood from the opened door and push on the latch to open it. You can go down to Home Depo and buy a piece of small round straight steel stock and form the end to make your own tool. Look at a friends car to see where to instert the tool.
bogus's Avatar
bogus
there is a tool for hood opening.
http://www.ecklers.com/product.asp?p...6U6UK6P9UJ9DC7
Old Jan 9, 2004 | 07:16 PM
415ZR1's Avatar
415ZR1
Default Re: '84 Driver side hood latch will not open... (bogus)
Thanks. The '84 is g/f's car. I have my '90 ZR1 to use has a "model". Probably will order the tool but will attempt to make one while waiting for delivery.
Thanks, John
Old Jan 9, 2004 | 07:48 PM
CFI-EFI's Avatar
CFI-EFI
It may be just an adjustment, or on a car as old as the '84, the cable may be stretched. I knew the cable needed replacing, when mine refused to open this past summer. I simply grabbed the cable with a pair of pliers and gave the offending strand a tug. I removed the latch pin from that side of the hood, and drove it on a single latch for the week it took for the new cable to come in. Good luck, and...
RACE ON!!!
Old Jan 9, 2004 | 07:58 PM
tlc85's Avatar
tlc85
on my 85 the cable on the inside of the car where the handle. there are two cables one for the left and one for the right. some times one of mine pop out of the clip. you might get lucky and check one of them. also if you have you car on ramps or jacks the flex of the car might not let the hood open. I always pop mine open if i do any of that. good luck
Old Jan 9, 2004 | 11:02 PM
Tourney3p0's Avatar
Tourney3p0
I was doing some work on my 88 and accidentally knocked the cable out of its retainer on the passenger side without noticing. I only realized my mistake when I went to open the hood and the passenger side failed to open.
I simply removed the wheel well by taking out a few screws, then reached up with my hand and pulled the cable. It opened fine.. total cost was nothing and it only took a few minutes to remove the screws then reinstall it.
Old Jan 9, 2004 | 11:50 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I always have the tool ready, just in case. Not so far.
But good luck to you.
tony
:smash:
Old Jan 10, 2004 | 03:10 AM
415ZR1's Avatar
415ZR1
Default Re: '84 Driver side hood latch will not open... (oldace84)
Thanks, gents. Good info. As this is the girlfriends '84 'Vette, got to keep that "can fix anything" attitude. Probably will delve into it this weekend. As of now, she is relishing in the "I don't have to check the oil every other tank of gas"!!! She is a motorhead at heart but is often caught in the latest designer wear which some how just doesn't look good (her opinion) with a Mobil 1 blot on her sleeve or manicure.
To '84 Driver side hood latch will not open...
