1989 Fuel injector replacement
Old Jan 10, 2004 | 01:03 AM
SkipI's Avatar
SkipI
Default 1989 Fuel injector replacement
I have the top end of my engine apart and was thinking of having the injectors cleaned and tested. I sent a note to Rich Jensen of cruizing performance and got the following reply:
If your vehicle has the injectors it originally came from the factory with, they will be the original gray/silver Multecs. Those particular injectors have the highest failure rate of any injector ever installed in the TPI engines. Because of this failure rate, I won't even attempt to clean them. You will be better off putting the money towards purchasing a set of replacements.
Sorry to be the bearer of bad news but that's just the way it is with those injectors. It's not a matter of if they will fail but simply a matter of when.
Thanks for inquiring about my services anyway.
Rich Jensen
Okay, so what is a good replacement injector for a stock engine?
Skip
Old Jan 10, 2004 | 04:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 1989 Fuel injector replacement (SkipI)
Wow, that's quite surprising as I had him recondition mine a copla years ago with great results. :confused:
Did you guys have "words", haggle over price or anything like that?
Old Jan 10, 2004 | 07:41 AM
Sam Lam's Avatar
Sam Lam
SkipI: Your story sounds a lot like my situation about 6 months ago. My 89 had two or three shorted injectors and was running like crap. I priced new GM injectors at $140 each. Rich at Cruzin recommended I buy a used set from the 87 or 88 vetts and have them serviced. I found a used set from a 88 model for $80 and had them checked by Rich. The total for both of these was less than $100. I recommend you ask Rich for advice as he is "straight shooter"! BTW, his first email to me had almost the same wording as found on your note. It appears many people with the 89 -91 model years are having "Multec disease"!
Old Jan 10, 2004 | 08:29 AM
subman's Avatar
subman
Try Bruce at fiveomotorsports.com I went with the 21# F*rd/Bosch. He puts the injectors on e-bay and the buy it now price for mine was $199.00. He is a straight shooter and will give you help if you need it.
Good Luck
Old Jan 10, 2004 | 10:40 AM
1MoorTym's Avatar
1MoorTym
Thats the exact same thing Rich told me 2 years ago, so hes not making this stuff up. He knows injectors, is an honest guy and is trying to save you money.
He sells Accels and I bought a set from him and they work just fine. Give him a call, he's very helpful and a great guy to deal with.
Old Jan 10, 2004 | 12:28 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Another one is Gordon @ witchhunter.com... did my injectors... great service and great guy...
Old Jan 10, 2004 | 02:10 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: 1989 Fuel injector replacement (subman)
Good Luck
:iagree: I have a set from them and they work great!!!
Old Jan 10, 2004 | 03:07 PM
ethan1321's Avatar
ethan1321
Default Re: 1989 Fuel injector replacement (grapeknutz)
Try at TPIS also, I think I remember someone on here saying that they have new bosch sets for 100 dollars.
Old Jan 10, 2004 | 03:34 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Default Re: 1989 Fuel injector replacement (65Z01)
65Z01,
The reason Rich did your injectors and won't do those for SkipI is the difference in injectors used for 88 and 89+ vettes. The 88s can be cleaned and rebuilt reliably, while the 89s can not.
Rich rebuilt my 88s this year with no problem, but refused to rebuild my brother's 89 injectors for the same reason goiven earlier. Rich is an honest guy and would rather lose a sale than see someone pay for a rebuild that won't last. I'd see what he is selling new and order that from him. His prices for new are about as good as anyone else online and he is good to do business with.
To 1989 Fuel injector replacement
