Need Help - Starting Problems (VATS System Engaged?)
When I tried to crank the car again I had no battery. When he tried to give me another jump start, the starter engaged fine but the engine never hit. We discovered quickly that the injectors weren't priming when I turned the key on.
Is this the method by the VATS system operates? Does it somehow kill power to the fuel pump or the injectors? The car was running perfectly prior to that second jump start. Also, I might have had the key turned on the second time we tried to attach the jumper cables. Any chance I might have fried a relay or something? Are there any known negative symptoms that come as the result of trying the attach jumper cables with the ignition key turned on?
If it's the VATS, how do I reset it!!
Hope I didn't fry something! :eek:
Thanks :thumbs:
Also, a spin around the block will not put much of a charge in your battery. You might consider connecting a battery charger on it for a minimum of 24 hours and several days is even better. Lead acid batteries self discharge about 1% every day and during discharge lead sulphate collects on the plates. Lead sulfate is a good insulator and if left long enough, you will have a door stop instead of a battery. Always periodically charge a battery that isn't in service for longer than 3 weeks. If you have a battery charger, buy an interval timer and have it charge your battery once a day on its shortest interval (usually 15 min). This will keep your battery up.
[Modified by jfb, 11:30 PM 1/10/2004]
I'm still confused as to why the car cranked perfectly on the first jump, only to not respond at all on the second jump. If it works with the new battery then I should be set. Thanks! :thumbs:
