Fuel Filter nut size
Old Jan 12, 2004 | 12:25 PM
C4SMAJ's Avatar
C4SMAJ
Default Fuel Filter nut size
anyone know what size wrenches it takes to change the fuel filter on a 96...lt1
thanks....
:seeya
Old Jan 12, 2004 | 12:56 PM
Blk-94's Avatar
Blk-94
Default Re: Fuel Filter nut size (C4SMAJ)
Think it's 10mm and 12mm, not sure, will have to check when I get home. Also, think someone posted the whole procedure on the TechTips.
Old Jan 12, 2004 | 01:29 PM
C4SMAJ's Avatar
C4SMAJ
Default Re: Fuel Filter nut size (Blk-94)
thanks Ill check there.... :seeya edit...found it..good info...thanks again...
[Modified by C4SMAJ, 12:34 PM 1/12/2004]
Old Jan 12, 2004 | 03:21 PM
JasonL's Avatar
JasonL
If you have trouble getting the outlet fitting off (cat is in the way), you can loosen the plastic fuel line clamp (looks like a plug wire loom) in the engine bay, near the black coolant tank. The two flexible braided fuel lines will allow you to pull the filter and line into the engine bay and rest it on the tire. Then you can easily remove the outlet nut.
Picked up that good tip from some old threads on here.
To Fuel Filter nut size
