Dash panel 91 Coupe
Old Jan 12, 2004 | 02:18 PM
THXBABY's Avatar
THXBABY
Cruise-In II Veteran
Default Dash panel 91 Coupe
The digital part of my dash in my 91 needs to be repaired. Can any one recommend a good repair shop?
Jim
Old Jan 12, 2004 | 03:11 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Dash panel 91 Coupe (THXBABY)
Do an archive search here... you'll find info there... :thumbs:
Old Jan 12, 2004 | 09:14 PM
THXBABY's Avatar
THXBABY
Default Re: Dash panel 91 Coupe (vinnies87)
Vinnie87
Thanks! After looking at all the links it would seem that they all refear to the 84-89. The dash is differant on the 90-96.
Jim :cheers:
Old Jan 13, 2004 | 11:32 AM
rick lambert's Avatar
rick lambert
Try Gordon Killebrew-just type that into your search on your computer, or you might try Batee.com
Although I've found several people on the forum seem to know just as much.Have you tried using the "search" on the forum?Most of these problems amount to either a bad ground or bad- dirty pin connections.The appearance might be different but I think the concept is the same.Good luck and let us know. :seeya
To Dash panel 91 Coupe
