Matching wheel bearings?
Old Jan 12, 2004 | 07:39 PM
kohlbear's Avatar
kohlbear
Default Matching wheel bearings?
Tech says replacing only one that is bad on the front is ok because they are in a hub assembly. Could not replacing both cause a pull? :nopity
Old Jan 12, 2004 | 07:43 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Matching wheel bearings? (kohlbear)
:cheers: No
If a bearing is turning freely, it's turning!
Replacing one should have no effect on the other, unless it too is bad
:seeya
:steering:
Old Jan 12, 2004 | 09:41 PM
sraft's Avatar
sraft
Default Re: Matching wheel bearings? (jackdaroofer)
:iagree: :iagree: :iagree:
Don't let them talk you into more work than you need.
To Matching wheel bearings?
