Fuel Cannister on a 91???
Old Jan 13, 2004 | 10:57 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Fuel Cannister on a 91???
Chasing my stinky fumes problem, I look for the cannister and vent lines.....NO CAN??? There is a check valve\solenoid thingy that is on the manifold with a return line back out to the back of the rear wheel well but theres a cover over that section and I wasnt in the mood today....
Is it there? I think there might just be another check valve back there, and that this thing vents itself into the manifold.
Funny thing is that after taking apart the valve\soleniod on the manifold and running some air into it and all the lines, the stink seems to have subsided. They were not clogged, I know that, but maybe the valve was stuck?
Old Jan 13, 2004 | 10:58 PM
bogus's Avatar
bogus
Default Re: Fuel Cannister on a 91??? (GusBustamanteJr)
the vent can is in the back... next to the tank.
Old Jan 14, 2004 | 12:13 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
My 95s is in the RR quarter panel. Found it when changing the side marker bulb. It's in the way of and made it a pita to change the bulb!
To Fuel Cannister on a 91???
