How often to change fuel filter?
Old Jan 16, 2004 | 09:52 PM
TheStef's Avatar
TheStef
Default How often to change fuel filter?
Hey guys, I'm just curious, how often do you change a fuel filter on our cars?
Old Jan 16, 2004 | 10:36 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: How often to change fuel filter? (TheStef)
Without checking the manual, I would say a good ballpark figure is 25,000 max. Cheap reliability insurance. If in doubt, change.
Old Jan 17, 2004 | 03:14 AM
GlockLT4's Avatar
GlockLT4
Default Re: How often to change fuel filter? (Corvette Kid NC)
Haha, if you've never done it before, you would know why "if in doubt" is something that doesn't matter that much, lol. I did mine recently when i put my headers on and had my cats out completely .. made it MUUUCCHHH easier. Normally it's very hard to do.
Old Jan 17, 2004 | 08:35 AM
RichS's Avatar
RichS
Default Re: How often to change fuel filter? (GlockLT4)
I change mine every winter as well as all the fluids. A bit extreem yes, but it's cheap insurance for me. :cheers: (other say a bit **** :D )
Old Jan 17, 2004 | 08:48 AM
Strick's Avatar
Strick
I change mine whenever I remove the X-frame and exhaust. I've done it once in the 4 years I've owned the car. When I do my clutch this winter/spring it will be changed again.
Old Jan 17, 2004 | 12:38 PM
dlmeyers's Avatar
dlmeyers
Default Re: How often to change fuel filter? (Strick)
BELIEVE 30K is the book answer.
As a matter of practice, would recommend replacing the fuel filter when:
Buying a car and not knowing the service history.
Anytime the fuel pump is replaced.
When the darn thing is really accessible.
Actually, between 20 and 30K should be OK for most applications.
dlmeyers 90 coupe zf6 3 speed shocks
Old Jan 17, 2004 | 01:23 PM
c4cruiser's Avatar
c4cruiser
The owner's manual for my 92 does not even show any recommendation for fuel filter changes, even though it lists a part description and AC Delco part number. The manual for my 87 doesn't mention a fuel filter at all. I've done mine once but it is not an easy job to do especially because the 92 is a vert and the X-brace has to come off to gt to it, much less get wrenches on it.
If you don't run the fuel tank dry or let the car sit all winter without adding a fuel stabilizer or buy really cheap gas, you may even get away with not changing it. The filter is not terribly expensive but the labor charge could be a bunch if you don't do it yourself.
With the right type of line wrenches and a way to get the car off the ground, it really isn't a nasty job; it's just in a bad location. Just make sure you relieve pressure in the fuel line before loosening the connections. Also try to get the fuel level in the tank as low as possible and the nose of the car up high so gas won't run out of the open line.
Old Jan 17, 2004 | 02:28 PM
TheStef's Avatar
TheStef
Default Re: How often to change fuel filter? (c4cruiser)
When you guys say, 25 30 k, do you mean miles or Kilometers?
I've only put like 12000 kilometers (7500 Miles) in 3 years "lost my drivers licence for a long time, don't ask"
I'm just wondering if its a good idea for me to change it since its been 3 years.
I know I should get service manual, but were is it situtated exactly?
[Modified by TheStef, 1:29 PM 1/17/2004]
Old Jan 17, 2004 | 02:30 PM
atotalnincompoop's Avatar
atotalnincompoop
once a year :yesnod:
Old Jan 17, 2004 | 03:08 PM
pwrful c4's Avatar
pwrful c4
Default Re: How often to change fuel filter? (dlmeyers)
:iagree:
Old Jan 17, 2004 | 03:09 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree: :thumbs:
Old Jan 17, 2004 | 03:15 PM
c4cruiser's Avatar
c4cruiser
The fuel filter is located along the inside of the right frame rail just behind the starter. If you open the hood and on the passenger side, looking down between the right side exhaust manifold and frame rail, follow the fuel hard lines and you shoud be able to see the front portion of the filter. The filter is about 5-7cm in diameter and the fuel line fitting is in the middle of it. The filter is held to the frame rail with a strap.
Mileage figures on the Fourm are normally in miles not kilometers, so 25K is 25,000 miles or about 40,000km. If the car sat for the time you were using "alternate" transportation, it probably wouldn't hurt to change the filter.
Old Jan 17, 2004 | 03:20 PM
TheStef's Avatar
TheStef
Yeah the alternate transportation is a 93 Mazda Precidia... beater car :lol:
I've just been doing oil changes on it and for the past 5 years its been holding up pretty good.
I really want to do the proper maintenance on the Vette though.
I found an article on the Tech tips section... holy crap! it looks like a hard job just to change the gas filter.
[Modified by TheStef, 2:22 PM 1/17/2004]
Old Jan 18, 2004 | 07:57 PM
dlmeyers's Avatar
dlmeyers
Hello again Stef,
Two points, the job is not really that bad. Just make sure you keep the front higher than the back and be sure to remove the gas cap.
Secondly, a partially clogged filter is likely the prime reason fuel pumps fail. When clogged, the differential pressure across the filter increases, and the pump must work harder pushing fuel through a clogged filter. Those little pumps do not appreciate extra work and will quit, bringing more grief. Again, fuel filters on fuel injected cars merit attention.
Old Jan 18, 2004 | 08:05 PM
RonRed89's Avatar
RonRed89
You should see what comes out of those things when you try "get away without changing it" Makes you wonder how the car even runs at all.
I change mine every 10K mi.
Ron
Old Jan 20, 2004 | 04:23 PM
TheStef's Avatar
TheStef
Default Re: How often to change fuel filter? (RonRed89)
I'm changing mine for sure this summer
Thanks guys!
Old Jan 20, 2004 | 06:07 PM
bully-3's Avatar
bully-3
i change mine every year due to gas sitting in the tank for long periods of time.
To How often to change fuel filter?
Old Jan 20, 2004 | 07:23 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
Default Re: How often to change fuel filter? (bully-3)
I do mine about every 15K. Probst, in his excellent F.I. book, says you really can't change it too often, and it is an often overlooked service item that is very important. Your injectors are so finicky, that some even recommend every 3K!
Old Jan 20, 2004 | 07:40 PM
Corvette Kid
If you get the car up high enough or have it on a lift, it's not really that bad to change. Not a breeze, mind you, but did mine in 20-30 minutes the first time. Buy quality like AC Delco, NAPA premium, etc.
Old Jan 20, 2004 | 08:55 PM
8835thL98's Avatar
8835thL98
Did it when i bought my car, uped my mpg.
