need help with trouble codes
Old Jan 18, 2004 | 12:50 PM
JACKSBLK94's Avatar
JACKSBLK94
Default need help with trouble codes
my 94 has the following codes, h21, h23, h37. these codes are are in the abs computer system. i have a service abs and a service asr on the dash. any help would be appriciated. thanks
Old Jan 18, 2004 | 01:15 PM
SunCr's Avatar
SunCr
Default Re: need help with trouble codes (JACKSBLK94)
21 & 23 are for the right front wheel sensor - 37 is the left rear sensor. Diagnosis ususally involves a special tool. Other than checking for obvious damage, I wouldn't know what else to recommend.
Old Jan 18, 2004 | 01:37 PM
JACKSBLK94's Avatar
JACKSBLK94
Default Re: need help with trouble codes (SunCr)
thanks for the help!! could worn break pads cause this error code?
Old Jan 18, 2004 | 01:53 PM
SunCr's Avatar
SunCr
I don't think so. From what little I know, sensors are an indication of vehicle speed based on voltage signals determined by the air gap between the toothed gears. Traction Control/ABS ECM uses this information to determine if the vehicle is skidding or if a wheel has locked up and pulses the brakes to control wheel spin. It could be the wiring - no or partial signal due to an open or poor mating at a connector or a damaged sensor. I think the 21 will only be generated if the vehicle is moving. The other two can be indicated with the key on or vice versa.
Old Jan 18, 2004 | 03:11 PM
Steel Blue 91's Avatar
Steel Blue 91
:iagree: However, since they are all proceeded by "h" they are history codes. Try pulling the battery cable (neg) for a min. or two, reconnect and go for a drive to see if they reappear.
Old Jan 18, 2004 | 06:10 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: need help with trouble codes (Steel Blue 91)
These codes should turn on the Service LTPWS light in the DIC (driver information center). Does the Service LTPWS light come on when you turn the key on? If it does not then the bulb is burnt out or as it was in my case, someone pulled it out :smash: .
Good luck :seeya
Old Jan 20, 2004 | 09:23 PM
JACKSBLK94's Avatar
JACKSBLK94
Default Re: need help with trouble codes (C4Crazy787)
the low tire pressure sensor is very interesting? i don't belive i have these....i thought this was an option? do you think someone pulled the bulb on me? this still does not explain the recent service abs and service asr lights?
Old Jan 20, 2004 | 11:53 PM
C4Crazy787's Avatar
C4Crazy787
Please, disreguard this post. I see now :bb that you are having trouble with wheel speed sensors if you have replaced the offending sensors and continue to see the DTC (diagnostic trouble code) could be the circuit or the ASR/ABS module.
If you don't have the GM service manual get one, http://www.helminc.com best 90$ I've spent!! :seeya
To need help with trouble codes
