does anyone else notice the AC compressor engagment while driving?
Old Jan 19, 2004 | 08:45 AM
Z06_BluByU's Avatar
Z06_BluByU
Default does anyone else notice the AC compressor engagment while driving?
I had a slight surge I thought was the result of too much spark.. however, I've come to realize it only happens when the A/C compressor is cycling.. if I turn the HVAC control head from 'auto' to 'off' I dont get the slight surge.. I don't remember this happening before I stroked the motor.. but maybe I just wasn't paying attention as much.. Also, The exhaust is much louder, so I can hear slight changes in engine while cruising.. does anyone else experience this? Is this normal? if not, any ideas how to eliminate this condition?
I would describe the symptom as a mild hesitation at low rpm cruise (under 2500rpm).. its momentary..
[Modified by BluByU, 1:17 PM 1/19/2004]
Old Jan 19, 2004 | 12:36 PM
GlockLT4's Avatar
GlockLT4
Default Re: does anyone else notice the AC compressor engagment while driving? (BluByU)
YUP! i feel mine. I did have the clutch replaced recently though, and i haven't felt it as much though. When i get the car back running again i'll let ya know. I haven't run the A/C much since i got the clutch replaced, haha... go figure (winter).
Old Jan 19, 2004 | 12:37 PM
vader86's Avatar
vader86
It happens to me, and its quite aggravating sometimes.
Old Jan 19, 2004 | 03:11 PM
Yellow95's Avatar
Yellow95
Default Re: does anyone else notice the AC compressor engagment while driving? (vader86)
Happens on mine, not as bas since I had the cooling system charged.
Old Jan 19, 2004 | 03:32 PM
lbitp37's Avatar
lbitp37
Default Re: does anyone else notice the AC compressor engagment while driving? (Yellow95)
On my 92,when in auto mode the compressor will engage/disengage, based on the temperature you selected.
Old Jan 19, 2004 | 03:40 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: does anyone else notice the AC compressor engagment while driving? (lbitp37)
:yesnod:
Old Jan 19, 2004 | 03:42 PM
abtanner's Avatar
abtanner
Never noticed that with my,'94 LT1,A4, stock exhaust. AC still has OEM 'charge'.
Old Jan 19, 2004 | 03:55 PM
Steel Blue 91's Avatar
Steel Blue 91
:iagree: Also, if you run with the defroster on, it will cycle the compressor.
Old Jan 19, 2004 | 04:01 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: does anyone else notice the AC compressor engagment while driving? (Steel Blue 91)
Correct, the compressor runs when in defrost mode, or in auto mode.. but can you guys feel it engaging when you drive? a slight hesitation..etc..etc..
Old Jan 19, 2004 | 04:04 PM
Matt Dusek's Avatar
Matt Dusek
Yep, I notice it on my '92 6-speed. Glad to see it's not just me.
Old Jan 19, 2004 | 04:19 PM
nonetooclose's Avatar
nonetooclose
Default Re: does anyone else notice the AC compressor engagment while driving? (Matt Dusek)
Happens to me too! It makes sense since I think it takes away approximately 20-30HP when engaged and compressing.
Richard
Old Jan 19, 2004 | 04:36 PM
GlockLT4's Avatar
GlockLT4
Default Re: does anyone else notice the AC compressor engagment while driving? (abtanner)
You won't notice it with an auto as the torque converter makes it so that the slight feeling with the clutch isn't felt. A manual you can feel it because it's direct through with no slipping.
Old Jan 19, 2004 | 05:50 PM
NightRyder's Avatar
NightRyder
ha ha ha! the first good thing about having a broken A/C. (mine)
and, you should see it on the honda.. all the lights dim and the tach drops a 3-4 hundred.
Old Jan 19, 2004 | 09:35 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: does anyone else notice the AC compressor engagment while driving? (GlockLT4)
I'm not so sure... look at my sig... I have an auto (A4) and I can feel it... weirdo..
Old Jan 19, 2004 | 09:38 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: does anyone else notice the AC compressor engagment while driving? (NightRyder)
:lolg: :lolg: :lolg: I suppose you could push in the cigerette lighter and see a 1000rpm drop in a honda... :lolg: :lolg:
I am stilll one of those people who consider *** cars the biggest joke to 4 stoker engines... totally disposable... (ok those and the chevy caviler) :p:
Old Jan 20, 2004 | 03:07 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
:iagree:
Old Jan 20, 2004 | 03:47 PM
Lone Ranger's Avatar
Lone Ranger
I can feel some slight drag kick in when the compressor comes online. Not much but its there.
To does anyone else notice the AC compressor engagment while driving?
Old Jan 21, 2004 | 07:22 AM
vetteoz's Avatar
vetteoz
Default Re: does anyone else notice the AC compressor engagment while driving? (Lone Ranger)
When is the compressor supposed to cycle? When it reaches the set temp?
Mine cuts in and out at like 15 sec intervals as soon as I turn the A/C on.In most thermostatic control situations the unit runs constant until the set temp is reached then cycles to maintain it.Have had system changed to eco friendly gas and new dryer.Works perfect but does not pull the temp down as fast as when running constant.Should it run when heating?
I can hear clutch engaging when using heat only.
Problem with electronic controller?
Old Jan 21, 2004 | 08:15 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: does anyone else notice the AC compressor engagment while driving? (vetteoz)
I think it engages anytime the "auto" function is used.. weather its heating or cooling.. I think it helps pull the moisture out of the air before entering the car... (this is also the same reason it runs when the defrost is on).
Old Jan 21, 2004 | 08:32 AM
Lone Ranger
Also, you want the A/C compressor to be used a little bit during winter driving because regular use keeps the seals in the A/C lines in good shape. If the compressor stayed offline for long seasons over and over the pressure line seals would go bad faster. At least thats's the way it used to be :)
[Modified by Lone Ranger, 7:33 AM 1/21/2004]
