Any difference between Earl's and Goodridge stainless steel brake lines?
Title says it all. If there is a difference, which is better? :seeya
Re: Any difference between Earl's and Goodridge stainless steel brake lines? (Rob 91Z07)
Nobody knows? :confused:
Rob- Don't have an answer on the Goodridge lines, but I' running Russell lines on my 92 vert and Earl's on my 87 coupe. The Earl's appear to be beefier and a little more well made than the Russell lines and they even seem to have a little extra length to them. There is just enough looseness to the Earl's lines when the car is off the ground and the suspension is unsupported. But I can't say if this is just teh difference between the manufacturers lines or the year of the cars.
I have read some good things about the Goodridge lines but they were C5 applications. HTH
Hope your're enjoying Texas!! We finally got the snow to melt away here in Olympia. :cheers:
St. Jude Donor '06
Make sure that the lines are DOT approved!
I have the earls on my 93 and they work just fine, the brakes are rock solid with my gs calipers and eradi rotors
I've got Goodridge lines on the vette and am happy wih them. Also, just got a Baer GT+ brake kit for the Z28 and it came with Goodridge brake hoses FWIW.
