problems magically disappear?
Old Jan 19, 2004 | 03:39 PM
Corvettaholic's Avatar
Corvettaholic
Default problems magically disappear?
Last week, my poor 85 sputtered like crazy, had no throttle response, and I got high off how rich it was running. So I went out of town over the weekend and let it sit in my garage. Came back, and its a whole new animal! When I stomp on it, it picks right up and actually revs without throwing a fit. fast too. What could cause this? I'm wagering that in a couple days of daily driving its gonna go back to being a slug, cause this sort of thing happened a long while ago. Typically, its always a slug.
things i've done: trickflow 195cc alum heads
things that've happened:
-ran into a mountain, body damage, hood don't open
-replaced o2 sensor 4 months back (still running rich)
-hacksaw'd off the mufflers and rear y-pipe (hangers broke)
-thrashed the interior
-rear main seal leaks (no surprise)
-random engine codes, usually for low voltage to fuel pump (?), maf/iac code, runs rich code, tps code, and i forgot the other one.
ideas why it likes to take long naps?
Old Jan 19, 2004 | 03:46 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: problems magically disappear? (Corvettaholic)
It probably hacked up a furball.......... :lolg:
Old Jan 19, 2004 | 04:43 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Default Re: problems magically disappear? (brdd)
:lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg:
Old Jan 19, 2004 | 05:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First off open the connector in the Or wire near the battery for a minute to clear the codes.
You might also carefully look into the MAF while someone shuts off the engine; if the sensor wires don't glow bright red for 2sec, replace the MAF burn-off relay. If ok, clean the contacts to the MAF; if the code comes back and no faulty ECM, replace the MAF.
If code 52 comes up just after startup, replace the FP relay; if it comes up later, replace the oil pressure switch.
The TPS code may go away with the MAF code but you can check the TPS voltages at base idle and at WOT to see if all is well.
You can use the ECM's field test mode (explained on my site) to see if the ECM is going/staying in closed loop mode; if not (since the O2 sensor is fairly new, replace the coolant temp sensor in front of the engine umder the TB.
Old Jan 19, 2004 | 06:07 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
thats a good wone :withstupid: :lolg: :lolg:
Old Jan 19, 2004 | 06:21 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Currently Corvette-less
Default Re: problems magically disappear? (vinnies87)
Gotta admit ~ that was pretty damn funny!!! :yesnod: :lol: :lolg:
Old Jan 19, 2004 | 06:37 PM
FX GS's Avatar
FX GS
Default Re: problems magically disappear? (PurpleC4)
:U
Old Jan 19, 2004 | 06:43 PM
Corvettaholic
Default Re: problems magically disappear? (FX GS)
I think after I run those tests and nothing comes up, gonna get the poor thing checked for a hairball problem. maybe you guys are on to something...
Old Jan 19, 2004 | 10:43 PM
autotech's Avatar
autotech
When all else fails - Replace the Ignition Module and Pick-up in the distributor - Confusedshush... :thumbs:
To problems magically disappear?
