Castrol 10W- 60 :)
Old Jan 20, 2004 | 12:01 AM
CaliforniaVette's Avatar
CaliforniaVette
Default Castrol 10W- 60 :)
It really woke up the ZF6 in my LT4. im very pleased with the results, shifts smoother, goes into 1st very nicely. and off topic i just got her back from the shop (got alighnment done) and it worked out very nicely, the car had some issues :U some wierd toe and caster settings, but they were taken care of along with a new Tie rod and she handles alot better, is very repsonsive and smoooth. When i got home i saw my brand new GS-D3's at my door step, when i get them on soon ill let you all know what i think
Old Jan 20, 2004 | 02:10 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Castrol 10W- 60 :) (CaliforniaVette)
:party:
Old Jan 20, 2004 | 06:34 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
The tranny oil change is on my list as well
Old Jan 21, 2004 | 02:57 AM
wake's Avatar
wake
Did mine too last weekend... Put 200 miles on the car afterward and it did make it shift easier/smoother...
Not a fair comparison though, I think the otherstuff was the original and 65K miles old... :lol:
Old Jan 21, 2004 | 03:48 AM
GlockLT4's Avatar
GlockLT4
Default Re: Castrol 10W- 60 :) (C4DC)
Yup, that's on my list of things to do too. i bought the oil, but now i just need to find a damn 19mm allen socket to use to get the fill/drain caps out. How much was your Castrol? The stuff from GM was $32 for 3 quarts.
Old Jan 21, 2004 | 12:29 PM
Batvetteman's Avatar
Batvetteman
I bought the oil and borrowed the tool (17MM) but someone has rounded out the hex in the plug! Any suggestions? :banghead:
Old Jan 21, 2004 | 01:04 PM
GlockLT4's Avatar
GlockLT4
Default Re: Castrol 10W- 60 :) (Batvetteman)
Oh, it's 17mm? You sure? I need to find one.
Old Jan 21, 2004 | 01:16 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
That 10-60 Castrol or BMW oil is the only oil to go in my ZF6. Wait till you try out the Goodyear tires. :D :D
Old Jan 21, 2004 | 01:42 PM
JasonL's Avatar
JasonL
Vise grips maybe? Order a new plug from the dealer first... they take a few days to get in.
Yes GlockLT4, it's 17mm allen, available from any auto parts store.
Old Jan 21, 2004 | 03:11 PM
GlockLT4's Avatar
GlockLT4
Default Re: Castrol 10W- 60 :) (JasonL)
Haha, apparently there aren't "any" auto store around here.. lol. I've tried everywhere.
Old Jan 21, 2004 | 03:56 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Default Re: Castrol 10W- 60 :) (GlockLT4)
Bought some 10 60 Castrol from BMW store. $27 for 3 litres.
Old Jan 21, 2004 | 05:39 PM
bogus's Avatar
bogus
Default Re: Castrol 10W- 60 :) (Dominic Sorresso)
I think that stuff is worth every penny... my transmission shifts sooo much better with it.
Old Jan 21, 2004 | 06:15 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Re: Castrol 10W- 60 :) (bogus)
Anyone else had any trouble getting the filler plugs loose? I have had my LT4 since new and have only 30K on it and have never checked the fluid since I cannot see any seepage or leaks.
Old Jan 21, 2004 | 06:28 PM
70ZZ3 96LT4
Batvetteman I do have an idea for you. Stick a bolt into the rounded off allen head plug that is a reasonable tight fit staurated with JB Weld. Let it cure, put a couple of nuts on the bolt, and then use a socket and braker bar to remove the allen head plug. I am sure there are other methods.
Old Jan 21, 2004 | 07:39 PM
1991Z07's Avatar
1991Z07
My plug was rounded off this last change...
Had to weld a bolt head into it. Arc welder did the trick, 'cause you just need to tack it into place. A pipe wrench finished the job just fine.
Bottom line is that I'll change it after every 5 changes from now on. I think the plug was $5, and well worth not having the frustration :banghead:
Wish I could find a plug just like it with torx head on it....
Old Jan 21, 2004 | 08:55 PM
DSPark13's Avatar
DSPark13
Just changed the oil in my tranny with the Castrol TWS synthetic 10W-60. Thought I would do it when I was in changing out the clutch. Tranny shifts great with that stuff, got it at the BMW dealership for $8.06 per liter. I asked for the club discount. I got the 17mm allen socket at AutoZone. The packet I bought included a 17, 14 and 12mm sockets for $7.99. :thumbs:
Derrick
Old Jan 21, 2004 | 09:53 PM
CaliforniaVette
i hammered my tool in there (lightly) and it created a new space for it. it was deformed but it worked just fine
Old Jan 22, 2004 | 02:42 AM
wake's Avatar
wake
I
I picked my 17mm allen up at Sears for $9...
Old Jan 22, 2004 | 11:18 AM
Batvetteman
Default Re: Castrol 10W- 60 :) (wake)
Thanks for the suggestions guys, I'll give it a try! :cheers:
To Castrol 10W- 60 :)
