Bushings
Old Jan 21, 2004 | 01:53 PM
kohlbear's Avatar
kohlbear
Default Bushings
Can bad bushings cause a car to drift and pull? How do you tell if they are bad?
Old Jan 21, 2004 | 01:54 PM
bogus's Avatar
bogus
Default Re: Bushings (kohlbear)
sure can effect alignment.
how many miles? how old?
time is as much a factor as mileage...
Old Jan 21, 2004 | 02:06 PM
kohlbear's Avatar
kohlbear
Default Re: Bushings (bogus)
87 z52 19k
:cry
Old Jan 21, 2004 | 02:13 PM
vader86's Avatar
vader86
they definitely can, and on an 87 there are sure to be a few that have mostly disintegrated by now no matter the mileage
Old Jan 21, 2004 | 10:57 PM
Frizlefrak's Avatar
Frizlefrak
Visual inspection. Noticeable play in the suspension. Unless your car has been in hermetic storage, at 17 years old, it needs new bushings.
Wander/pull can be caused by a number of things. A tire with a tread separation, a bad wheel bearing, out of alignment, worn steering rack, bad bushings, etc. Start by checking for worn or deteriorated bushings. Try rotating tires. Do the easiest and cheapest first. Good luck.
To Bushings
