Brake Light question
Old Jan 21, 2004 | 06:34 PM
oderja's Avatar
oderja
Default Brake Light question
On my 86 the brake light on top of the hatch doesn't work how do you get to the blubs to check them? I thought I ask before I broke something!!
Thanks,
:confused:
Old Jan 21, 2004 | 06:46 PM
TheStef's Avatar
TheStef
Default Re: Brake Light question (oderja)
Under the rear bumber, you need small for arms to reach any of the lights back there.
Old Jan 21, 2004 | 06:57 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Brake Light question (TheStef)
He has a coupe, the third brake light is on top of the hatc.
Take a T-25 I beleive and open the hatch and you'll see the torx bit on the underneath side. Undo those two bolts and then close the hatch. And pull up on the brake light housing. You'll be able to access everything. And those bulbs aren't cheap. I'd check continuity of the wire as well to make sure it's not a pinched wire.
Old Jan 21, 2004 | 07:09 PM
TheStef's Avatar
TheStef
Default Re: Brake Light question (Jeffvette)
oops! just trying to help
I had to change one of the rear light bulb... talk about a job, my hole arm was scratched.
Old Jan 22, 2004 | 11:00 AM
oderja's Avatar
oderja
Thanks guys I was hoping you could just pop off the lens but I guess not. The car has just been repainted so the 3rd eye is clear coated to the hatch. I guess I just take a razor blade and cut around it I dont want to pull the clear coat off the hatch! I'll check the continunity before I do that though.
Thanks again for the help! :thumbs:
To Brake Light question
