SPIROLOX.....HTF do I gettem out?
Old Jan 21, 2004 | 09:24 PM
pablocruise's Avatar
pablocruise
Default SPIROLOX.....HTF do I gettem out?
ok, working on my shortblock. I need to get the pistons off the rods, and am not sure how to get the spirolox off. Help!
:confused:
Old Jan 21, 2004 | 09:29 PM
bogus's Avatar
bogus
Default Re: SPIROLOX.....HTF do I gettem out? (89 Paul in Cal)
http://www.kaydon.com/spirolox/spirolox.asp
http://www.daemar.com/spirolox.html
maybe that will help?
Old Jan 21, 2004 | 11:51 PM
superlund's Avatar
superlund
Default Re: SPIROLOX.....HTF do I gettem out? (bogus)
I hate removing those things major PITA, I started taking the piston / pin / rod assembly back to the machine shop & let them do it, they get plenty of practice. Disassemble, Clean, Magnaflux, & record the big / small rod end dimensions cost $100 for all eight.
Old Jan 22, 2004 | 12:30 AM
StealDads67's Avatar
StealDads67
Its a PITA to get them on until you get the hang of it.....
Gettin them off... Now that is really no fun.... I know...
They acually arent to bad once you get the first 2.. then you figure out hows it supposed to be done.. then its starts gettin easier
Old Jan 22, 2004 | 02:44 AM
pablocruise
:D you guys have me on the edge of my seat :D
Almost got an answer there. :D
How do I actually physically get them out? What tool do I use? What technique? Needle nose pliers pulling them out?
Old Jan 22, 2004 | 07:46 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
use an awl or a small regular slotted screw driver and dig into the end of the spirolock and start the end out and work the rest of it out its not to bad once you do a few :cheers:
Old Jan 22, 2004 | 04:22 PM
superlund's Avatar
superlund
Default Re: SPIROLOX.....HTF do I gettem out? (CORKVETTE1)
I always ended up scratching the pistons & tearing up my fingers, just plain got tired of messing with it, like CORKVETTE1, mentioned you have to get the end started and then kind of keep "unscrewing" them up and out. They form a helix, and the tension from that spring-loaded helix is what retains them in place. You may know this, but I just read the entire thread again, and noticed no one has mentioned these are not designed to be reused; you basically destroy them upon removal...
[Modified by superlund, 5:04 PM 1/22/2004]
Old Jan 22, 2004 | 11:27 PM
pablocruise
I got them out!
A swiss army knife's blade did the trick!
Thanx Andy for providing links showing what they look like. Based on that, I tried the swiss army knife blade.
To SPIROLOX.....HTF do I gettem out?
