LT1 Head Gasket thickness ?
Old Jan 22, 2004 | 09:21 AM
93 ragtop's Avatar
93 ragtop
Default LT1 Head Gasket thickness ?
I understand that you can purchase a fel-pro head gasket that has a thickness of .039 . Is the factory gasket .049 ? Also, I understand the impala gasket is .029. If all of this is true, would there be any problems with using the impala gasket and a hot cam? And is the dealer the best source for the impala gasket?
Old Jan 22, 2004 | 10:41 AM
STL94LT1's Avatar
STL94LT1
Default Re: LT1 Head Gasket thickness ? (93 ragtop)
The Impalla SS head gaskets will give you an additional .5 compression. They work great on my car, I would highly recommend.
Imp SS head gasket part # 12553160
Call Chris May at Superior Chevrolet, he'll hook you up.
(800) 728-8267
Old Jan 22, 2004 | 11:10 AM
93 ragtop's Avatar
93 ragtop
Default Re: LT1 Head Gasket thickness ? (STL94LT1)
(800) 728-8267
But do you know what the orig. gasket thickness is on the corvette LT1? To elaborate on this a little more, I have a set of heads that have been ported, and they have 58cc chambers. I am trying to determine how much to mill them to get back to a 54cc chamber, or possibly getting there with a .020 thinner headgasket. By the way, I deal with Chris on all my factory parts. He is a good man. :cheers:
Old Jan 25, 2004 | 03:01 PM
BryanC's Avatar
BryanC
Stock LT1 gasket is .050". Stock cc size is 54 cc, stock deck height will be about .022-.025", and the valve relief pockets are -5cc.
There is a good calculator here.
http://www.syty.org/old/calculator.html
Old Jan 25, 2004 | 03:18 PM
superlund's Avatar
superlund
Default Re: LT1 Head Gasket thickness ? (BryanC)
:iagree:
Mr Gasket is also making an LT series head gasket now, I believe it is .026 compressed, and Cometic makes one that measures .020, double check my numbers, but they are very close.
I've seen the LT series combustion chambers rated from 54.4 CC - 56.0 CC, I used a large syringe and measured 53 CC, on my LT4 heads, I'll know what a professional burette setup measures in CC's tomorrow....
To LT1 Head Gasket thickness ?
