Lt1 water pump question
Old Jan 22, 2004 | 04:28 PM
frankrizzo1's Avatar
frankrizzo1
Default Lt1 water pump question
guys....
i'm in the middle of replacing water pump on a 94...
took old pump off and am getting ready to install new one....
however.... i noticed a little play in the camshaft drive gear....
is this normal?
Old Jan 22, 2004 | 04:41 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Lt1 water pump question (frankrizzo1)
I dount think play is a good think.. as it will cause the seal where the gear penitrates the timing chain cover to eventually fail.. could you quantify how much play is a little?
Old Jan 22, 2004 | 06:50 PM
frankrizzo1
hard to explain.....
the play just seems a little excessive I guess.....
To Lt1 water pump question
