4+3 running very hot
Old Jan 22, 2004 | 09:23 PM
atotalnincompoop's Avatar
atotalnincompoop
Default 4+3 running very hot
i had this problem a while back, i figured one of the tranny lines was plugged, so i blew them out with an air hose, the problem went away, but now its back. :cry
what would be causing this, it gets so hot that you almost can't put your arm on the consol :yesnod:
Old Jan 22, 2004 | 09:48 PM
scorp508's Avatar
scorp508
Default Re: 4+3 running very hot (atotalnincompoop)
Wow, if true that will really kill the overdrive quickly. It might be worth it to have the tranny cooler portion of your radiator flushed.
Old Jan 23, 2004 | 11:40 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
bummer,,, that sounds like it could kill the tranny for sure.... :eek:
Old Jan 24, 2004 | 10:46 AM
atotalnincompoop
Default Re: 4+3 running very hot (scorp508)
is there a product that i can add to help with this, or must i take it in?
Old Jan 24, 2004 | 12:18 PM
bogus's Avatar
bogus
you should be able to DIY... if it's like any other tranny cooler it's on the radiator.
remove both transmission lines from the radiator, and block off the bottom one... I would get some Transmedic, feed it and fill up the cooler, let it work for a little while, remove the bottom plug and let it drain. maybe hit it with some brake cleaner and then compressed air.
if that don't do it, you will need to check into a standalone cooler.
:thumbs:
[Modified by bogus, 12:21 PM 1/24/2004]
Old Jan 24, 2004 | 12:32 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: 4+3 running very hot (bogus)
I agree with scorp..get it power flushed..the rad system is pretty simple, there's a blockage some were, but I don't think it's in the radiator. Best of luck and hope its a cheap fix. :cheers:
Old Jan 24, 2004 | 12:54 PM
atotalnincompoop
how big of one do you think i would need andy?
Old Jan 24, 2004 | 02:16 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Are you sure its the tranny and not the cat? Mine gets this way too sometimes, and I assumed it was the cat. Although, I haven't noticed it with the new high flow cat on there yet.
I've had no trouble with the 4+3 od operating correctly. Now you've got me scared, I should maybe put in a tranny temp guage anyways. :(
Old Jan 24, 2004 | 02:27 PM
atotalnincompoop
Default Re: 4+3 running very hot (CentralCoaster)
no cats :nonod: :thumbs:
To 4+3 running very hot
