Vibration/Rattling under car
Old Jan 23, 2004 | 09:12 AM
eric_daniel's Avatar
eric_daniel
Default Vibration/Rattling under car
When just driving slow like in a parking lot (5-15 miles per hour) and running about 1500 rpms, there is a light rattle under the car. It sounds like something is loose. You have to have the windows down to hear it. Since I don't have a lift at my disposal and I haven't had a chance to get my oil changed, I can't get under the car to see if I can see where its coming from.
Any ideas, other than just a ragged-out car!!!!!!!!
Old Jan 23, 2004 | 10:24 AM
fullboogie
Default Re: Vibration/Rattling under car (eric_daniel)
When I had that problem, I found a loose muffler hanger bolt in the rear.
Old Jan 23, 2004 | 10:58 AM
96BLKTN's Avatar
96BLKTN
Default Re: Vibration/Rattling under car (fullboogie)
When I had a rattle I found a loose O2 sensor. Thought is was coming from the trans. But just use a jack and some stands get under and check it out. I cleaned all of the junk under the car last time I was under it...
Old Jan 23, 2004 | 11:07 AM
Tourney3p0's Avatar
Tourney3p0
There are lots of things that can rattle under there. For me, it was the metal line that goes between the catalytic converter and the diverter valve. It was vibrating against some other lines in the same area.
Old Jan 23, 2004 | 02:40 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Time to get under there and "Shake, Rattle, Roll"...... :cool:
Old Jan 23, 2004 | 03:21 PM
eric_daniel
Default Re: Vibration/Rattling under car (vinnies87)
:lol: That's the next plan on the agenda.....I just wanted to see if there were any specifics to look for right off the bat. :lol:
I had thought of the exhaust hanger but just haven't looked yet. Thanks!!!!
Old Jan 23, 2004 | 03:23 PM
SonnyinVA's Avatar
SonnyinVA
knock on the cat. converter... sometimes they will break loose inside the housing and rattle like that. could also be the heat shield on the cat.
just climb under there and start shaking things.
Old Jan 23, 2004 | 03:24 PM
tdock's Avatar
tdock
A bad cat-converter can rattle, usually at lower rpm's or idle too. Sounds like rocks in a coffee can.
[Modified by tdock, 2:25 PM 1/23/2004]
To Vibration/Rattling under car
