Headlight Issues
Old Jan 23, 2004 | 07:38 PM
skybolt31's Avatar
skybolt31
Default Headlight Issues
I picked up my "new" 86 last night and had one low beam headlight out on the way home, the highs worked great, but one low beam was out. I went to take the bulb out today and being a complete novice with Corvette headlights, looked in the manual and it said to turn the headlights on and then move the switch to parkign lights and the headlights would stay open. I did this and it didn't seem like I was going to be able to get to the headlight, so i then moved the switch to off and only the right headlight closed, the left one, the one wtih the bad low beam stayed open. So I cycled the switch to headlights again and the right one opened and now the left one was working on the low beam also!! I cycled the switch again and now I am back to where I was before with the lights opening and closing properly but the left one not working on low beam.
Has anyone seen this type of thing before?
Assuming I have to change the bulb, is there an easy way to get at the screws to remove the cover to get at the bulb?
Thanks,
Bruce Green
Old Jan 23, 2004 | 08:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Headlight Issues (skybolt31)
Congrats on you new Vette and welcome to the Forum.
I think the flakey light on/off indicates you should change the bulb, though you might check connectors for good contact at the plug to the bulb.
Inspect wiring going to the headlight motor as someone might have done some bad splicing (happened with my turn signal wiring).
The headlight not going up/down sounds like a problem with the motor, if all connections & wire in sound.
Old Jan 24, 2004 | 12:46 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Congrads and welcome to CF: :thumbs:
Old Jan 24, 2004 | 08:21 AM
Brimis's Avatar
Brimis
Disconnect power from the left lamp, you should be able to locate the connector by viewing your manual. Then locate the small manual **** on the lamp assembly which is used to open and close your lamps. Turn the **** unitl the screws holding the cover in place are accessible.
As for your "winking" issue, have a helper turn the lamps on then make sure the cover is not getting stuck on the lamp opening. As the lamps are turned on press on the lamp in question, it may open.
I had the same problem with both lamps, intermittently. I removed the motors only to find they were okay. After I reinstalled the motors I was able to turn the lamp manually with no problem, but when I applied power they would wink. It was at this time I noticed the cover getting stuck. I realigned both covers and now my lamps are fine.
Good luck with your vette.
[Modified by Brimis, 8:23 AM 1/24/2004]
Old Jan 24, 2004 | 04:47 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: I think you have plenty of good advice so far, but I couldn't help but notice that you live in Westfield Mass. We get up there about three times a yearto visit or Son, Daughter in Law and two grand Daugters :D
Welcome to the Forum
:seeya
:steering:
Old Jan 24, 2004 | 05:27 PM
eddieL98's Avatar
eddieL98
Default Re: Headlight Issues (jackdaroofer)
I just came in from fixing mine. it had a diffrent problem but this might help. pull the connectors at the bulb and clean them. mine were so dirty that my lights were dim. cleaned them up and the worked great.
as for the motor check the little black box that the motors are connected to.
well first cycle the light is you hear noise from the motor then it's the gears. if no noise check the box. mine went out about a year ago. cost $130 to replace(dealer item)
hopefully you only have to clean the connectors. best of luck :thumbs:
Old Jan 24, 2004 | 06:30 PM
skybolt31's Avatar
skybolt31
Default Re: Headlight Issues (eddieL98)
Thanks for the tips, today the lights have been going up and down ok, just no low beam on the left side. I will get the bulb out of there, it has just been too dammm colddddddd!!
Old Jan 25, 2004 | 03:28 PM
skybolt31's Avatar
skybolt31
Found the problem!
I opened the hood up and started moving wiring aroudn and there was a connector, a grey one and moving that around would make the light go on and off. So at least now, I know where the problem is, separating it and putting it back toegether didn't fix the problem, so the next step is to figure out what to do about it. Splice the wires together, new connector??
To Headlight Issues
