Ahhh, ok, there is a certain voltage, .525 I believe, required to have the TPS properly adjusted. Does this value change with the addition of a larger throttle body?
Edit: I deleted "WOT" from the original post as it wasn't needed in the question.
Re: Idle voltage the same with bigger TB? (TuffShift)
The TPS voltage range remains the same.
.54 volt +/- .075 meaning anything from .615 to .465 is within spec.
You may have to adjust the minimum airflow setting using the screw on the throttle body to get the best idle, transition from idle to part throttle and back again.
Jake
Re: Idle voltage the same with bigger TB? (atotalnincompoop)
Thanks Jake, the "total one", and the others for all your help. I wasn't sure and figured it better to ask, than to jump in the water without knowing how deep it was.
I've made some pretty stupid mistakes over the years, ya know, from doin' just that.
:thumbs:
