Hard Start Lt1
Old Jan 24, 2004 | 01:51 PM
GRN93VRT's Avatar
GRN93VRT
1st Gear
Default Hard Start Lt1
My 93 vette (stock Lt1) has begun to take too long to start after the car has been run (fully warmed up) and parked for a while.
From a cold start, it cranks over immediately and runs perfectly.
The problem is that it takes considerable cranking to re-start after the car has been driven and parked for a while.
I am betting that it is a fuel delivery problem as I have found that tapping the gas pedal results in a quick start.
Any advice on what to look for would be appreciated.
Thanks,
LB
Old Jan 25, 2004 | 09:41 AM
ittlfly's Avatar
ittlfly
Default Re: Hard Start Lt1 (GRN93VRT)
Just form your symptoms, I would guess that your injector(s) are leaking. You need to put a fuel pressure guage on the schrader valve. There is a procedure for checking the fuel system including injectors. Post back if you need it.
