Door freezes shut, fixes?
Old Jan 24, 2004 | 07:13 PM
buzzbomb's Avatar
buzzbomb
Default Door freezes shut, fixes?
The doors on my '84 freeze shut over night. Seems that the weatherstripping get wet, then freezes to the door frame. Is there anything I can spray on the stripping to keep this from happening. thanks
Old Jan 24, 2004 | 08:58 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Door freezes shut, fixes? (buzzbomb)
Well, you had to expect someone to respond with this one: Move to a warmer state?
You could try applying dielectric grease to the rubber where it touches?
Old Jan 24, 2004 | 09:10 PM
buzzbomb's Avatar
buzzbomb
Default Re: Door freezes shut, fixes? (edsalinas)
That would be the best way to fix it, but I'm not sure I can do that before the ice storm they're predicting tomorrow morning. My Jeep is in the garage taken apart, so the other obvious one doesn't work either. I do appreciate the comments though. :cheers:
Old Jan 24, 2004 | 09:15 PM
edsalinas's Avatar
edsalinas
Good luck, and stay warm......... Easy for me to say here in Tucson Arizona huh?
Old Jan 24, 2004 | 11:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For cold weather you could rub a thin layer of parafin wax onto the weather strip so that water would roll off.
Any treatment that leaves a surface layer on the rubber will work.
Old Jan 25, 2004 | 12:03 AM
edsalinas's Avatar
edsalinas
Default Re: Door freezes shut, fixes? (65Z01)
For cold weather you could rub a thin layer of parafin wax onto the weather strip ..............
Neat idea, hadn't thought of that one..............
:cool:
Old Jan 25, 2004 | 12:21 AM
Perfusion's Avatar
Perfusion
Vaseline, maybe?
Old Jan 25, 2004 | 12:40 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
that should work, and conditions at the same time... i apply a coat to all weatherstrip each washing.... :thumbs:
To Door freezes shut, fixes?
