Were to get cold start elimiator?
Old Jan 24, 2004 | 08:01 PM
vetteguy216's Avatar
vetteguy216
Default Were to get cold start elimiator?
I tried to search for it but for some reason nothing comes back for any subject I type in?
I forgot the place that sells the cold start eliminator kits I am mainly just looking for the cap to go on the end of the fuel rail thanks guys.
Old Jan 24, 2004 | 11:09 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Were to get cold start elimiator? (vetteguy216)
http://www.hotrodlane.cc/
Go to Multiport injection page of online catalog. In Tuneport Accessories you will see #4 85-88 TPI Rear Fuel Rail plug.
I had a hard time finding one, too.
Old Jan 24, 2004 | 11:58 PM
SBNova's Avatar
SBNova
Is it neccesary to plug the fuel line or can the injector just be unplugged electrically? I am in need of this mod soon when I change to a 165 w/6E def.
Old Jan 25, 2004 | 12:30 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Were to get cold start elimiator? (SBNova)
I do not see why you cannot just unplug it. I use the SR intake that does not have the cold start so I eliminated the cold start completely.
Old Jan 25, 2004 | 03:34 PM
Hole-Shot's Avatar
Hole-Shot
Why do you want to eliminate it?
It will start hard (cold start) without it, unless you have the chip tweaked...or maybe you will get lucky and it will still cold start fine.
Old Jan 25, 2004 | 03:39 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Re: Were to get cold start elimiator? (Hole-Shot)
http://www.speedscenewiring.com has them i think there $30 or less talk to greg or zak
they are also a supporting vendor
Old Jan 25, 2004 | 05:09 PM
vetteguy216
Default Re: Were to get cold start elimiator? (85vet)
I to am putting on a superram all I needed was the end cap for the fuel rail. It is only $5 hotrodlane.cc.
And if you aren't using the superram you can just leave the cold start un pluged the superram intake doesent have the provisions needed for the cold start.
Thanks for the help guys.
To Were to get cold start elimiator?
