!@#%$%^ I HATE OPTIPARKS!
Old Jan 24, 2004 | 08:07 PM
R23HTC's Avatar
R23HTC
Default !@#%$%^ I HATE OPTIPARKS!
This is the last GM OPTIPARK I'll every have on my car. DynaSpark just as soon as money allows.
Cars is down again till then because of this !%)^ corrosion. New opti, new harness, 3 months later, this crap! :mad :mad :mad :mad :mad
Old Jan 24, 2004 | 08:12 PM
GlockLT4's Avatar
GlockLT4
Default Re: !@#%$%^ I HATE OPTIPARKS! (R94 LT 1)
Yup, looks horrible... and makes no sense.......
Old Jan 24, 2004 | 08:23 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
We all hate 'em, and I agree, there's no reason that should be happening. But, I think you have an electrical problem CAUSING that to happen??? I'd look deeper into the circuit, cause there's something else going on there for sure......
:reddevil :reddevil :reddevil :reddevil
Old Jan 24, 2004 | 08:28 PM
GlockLT4's Avatar
GlockLT4
Default Re: !@#%$%^ I HATE OPTIPARKS! (edsalinas)
Possibility of the MSD coil causing it? Too many volts for the circuit of the optiSpark?
Old Jan 24, 2004 | 08:52 PM
edsalinas's Avatar
edsalinas
Default Re: !@#%$%^ I HATE OPTIPARKS! (GlockLT4)
that looks more like a moisture, or corrosion, or acidic reaction, than a high voltage situation? Just guessin'.......
EDIT:
Flip the rubber boot over a little, is there anything going on inside it? Any destruction at all?
[Modified by edsalinas, 6:55 PM 1/24/2004]
Old Jan 24, 2004 | 09:26 PM
GlockLT4's Avatar
GlockLT4
EDIT:
Yeah, first thing I thought of when i saw it was acid corrosion....
Old Jan 24, 2004 | 09:28 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Have it cleaned out then use some Dielctric grease in there, that will keep most of the corrosion out.
Old Jan 24, 2004 | 09:34 PM
GlockLT4's Avatar
GlockLT4
Default Re: !@#%$%^ I HATE OPTIPARKS! (steve40th)
He did ... the thing was covered in it. Unfortunately the wiring harness is $80 and one of the leads on it was sooooo corroded that when trying to clean it, it just fell out.
Old Jan 24, 2004 | 10:14 PM
Lone Ranger's Avatar
Lone Ranger
It looks like some sort of chemical reaction ate up the terminal plastic. I've never seen something like that before. Very strange indeed.
Old Jan 24, 2004 | 10:42 PM
R23HTC's Avatar
R23HTC
Default Re: !@#%$%^ I HATE OPTIPARKS! (Lone Ranger)
Yeah, from that one pic it actually looks like one of the pins inside the opti completely corroded off and is probably stuck inside that plug. All that junk is trash now. At least with the DynaSpark this won't be an issue as they solder and seal that connection.
Old Jan 24, 2004 | 11:51 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Get one, you'll love it. :thumbs:
Old Jan 25, 2004 | 12:47 AM
Z51JEFF's Avatar
Z51JEFF
This grease will do the trick.
Old Jan 25, 2004 | 12:48 AM
GlockLT4's Avatar
GlockLT4
Default Re: !@#%$%^ I HATE OPTIPARKS! (z51jeff)
Have it cleaned out then use some Dielctric grease in there, that will keep most of the corrosion out. This grease will do the trick.
Apparently not well enough! lol
Old Jan 25, 2004 | 01:07 AM
R23HTC's Avatar
R23HTC
THAT WAS PACK full of grease and now look at it. Didn't work on this. :mad
Old Jan 25, 2004 | 01:14 AM
bogus's Avatar
bogus
that corrosion is odd... could some coolant be getting in there? I mean.. check your throttle coolant lines. if it's leaking down that way, it would do this.
those are low voltage signal lines. somethign nasty has gotten in there.
you know what I would do? take that lead to your local college/university and have the chem lab figure out what happened...
[Modified by bogus, 1:15 AM 1/25/2004]
Old Jan 25, 2004 | 02:13 AM
R23HTC's Avatar
R23HTC
Default Re: !@#%$%^ I HATE OPTIPARKS! (bogus)
No throttle coolant lines.
Old Jan 25, 2004 | 03:21 AM
steve40th's Avatar
steve40th
Was the corrosion anywhere outside of the plug. It looks really weird, as blue is not a normal corrosion in a car, usually white corrosion. It almost looks like a cleaner.
To !@#%$%^ I HATE OPTIPARKS!
Old Jan 25, 2004 | 09:10 AM
Strick's Avatar
Strick
How about this, your battery connections will make this greenish white residue when you don't have a clean and positive connection. Is it possible that one of the pins really didn't have a good enough connection? What color would the dialectric grease turn when it is subjected to sparking? Just a WAG.
Old Jan 25, 2004 | 10:12 AM
R23HTC's Avatar
R23HTC
I haven't seen anything like that outside of that location.
Old Jan 25, 2004 | 10:14 AM
R23HTC's Avatar
R23HTC
Default Re: !@#%$%^ I HATE OPTIPARKS! (Strick)
I had the same corrosion before, without the dielectric grease, so it's been present on two different harnesses with and without grease. :mad
