Aftermarket TPI gaskets???
Old Jan 25, 2004 | 12:42 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Aftermarket TPI gaskets???
Since search is down, let me just ask.
I have AS&M runners. A ported plenum, and an Accell superram base. Do I need special gaskets for these, or will the basic set work? Do they need to be matched?
Also, what gaskets did you guys use for the intake (i.e. felpro #....)
Thanks guys!
Old Jan 25, 2004 | 01:25 PM
USAsOnlyWay
Default Re: Aftermarket TPI gaskets??? (USAsOnlyWay)
TTT
The intake gasket is for the superram base to 113d ports. I know tons of you have these! :smash:
Old Jan 25, 2004 | 03:39 PM
Hole-Shot's Avatar
Hole-Shot
No special gaskets are needed. A standard set should fit fine. I have seen some that needed a little bit of cutting to compensate for large port-work.
Felpro 1204(stock size) or 1205(ported) will work for the intake manifold.
:cheers:
Old Jan 25, 2004 | 04:03 PM
USAsOnlyWay
Default Re: Aftermarket TPI gaskets??? (Hole-Shot)
Thanks!!!
Installation date is slowly approaching!!!
:seeya
To Aftermarket TPI gaskets???
