Flow # for GM Fast Burn heads???
Old Jan 25, 2004 | 11:25 AM
VetteNoob's Avatar
VetteNoob
Default Flow # for GM Fast Burn heads???
Does anyone have GM's flow numbers for these heads?
TIA!
Old Jan 25, 2004 | 01:57 PM
torquejunky's Avatar
torquejunky
Default Re: Flow # for GM Fast Burn heads??? (VetteNoob)
This link has the prototype flow numbers from GMPP and then at the bottom has flow numbers for the production heads & some others.
http://www.sallee-chevrolet.com/Fast...der_Heads.html
Old Jan 25, 2004 | 02:32 PM
VetteNoob's Avatar
VetteNoob
Default Re: Flow # for GM Fast Burn heads??? (torquejunky)
AWESOME! Thanks for the link!
Old Jan 25, 2004 | 10:45 PM
Red Hot 916spd's Avatar
Red Hot 916spd
I have a set on my 91 and have a sweet combo. Put these heads with a Tuned port induction specialties intake and a zzx409 cam full length headers an xpipe roller rockers and 24lb injectors I've got a small stroker crank offset grind the crank to a 3 and 9/16 stroke for a 364 combo use JE pistons to yield 11to1 comp. get your chip reburned to accomadate the new flow. put a better coil in the car with factory 3.54 rear gear mine pulls 117 upgrade to 4.09 and the car should run 120-122 1/4 w/out nitrous or any other power adder unless your up 5000 ft elevation? oh and thats full interior of course :reddevil
To Flow # for GM Fast Burn heads???
