more idle questions/problems....need help
Old Jan 25, 2004 | 11:58 AM
89blkvet's Avatar
89blkvet
Default more idle questions/problems....need help
when i start my 89 (cold) it idles VERY smooth, sure a little high due the cold, but when it gets to opeating temp, 175 plus, the idle is horrible, it jumps all over the place. I tried to adjust the TPS, no sucsess.....it seems fine for a while, then again, it's all over the place. Am I missing something here.....help !!
Old Jan 25, 2004 | 12:06 PM
greg84's Avatar
greg84
Default Re: more idle questions/problems....need help (89blkvet)
hi,any engine codes? last time the vette had a tune up etc.greg84 :cool:
Old Jan 25, 2004 | 12:09 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Here's the tech tip on setup: https://www.corvetteforum.com/techti...D=55&TopicID=2
You might also clean the throttle body , helped mine...
I also have an excellent doc done by one of the CF guys in word format, very complete and easy to follow,,, If you want a copy, email me and i'll send it... :cool: :thumbs:
Old Jan 25, 2004 | 12:16 PM
89blkvet's Avatar
89blkvet
Default Re: more idle questions/problems....need help (vinnies87)
Tune up very recent......not even 2,000 miles ago. Replaced plugs, cap, rotor, ignition module, maf relay, egr valve and switch.......I am chasing something.....
To more idle questions/problems....need help
